Reply 20 of 29, by Kahenraz
idspispopd wrote:
meljor wrote:
I just wonder why it is that v1 and voodoo rush are having trouble with fast systems, even though the pci bus is running at a normal 33mhz.
My guess that the game/driver/other software component has to wait until something (texture upload?) has finished and the wait is simply not long enough on a fast enough CPU.
I went into more detail about this in another thread; it's most likely bits rolling over. it would be the same thing as the buffer overflow bug in the MT-32, or close to it.
Reply 21 of 29, by Mau1wurf1977
Kahenraz wrote:
How would you compare it to a Voodoo 1 or 2? I've never owned one so I can't make a comparison.
I'm planning on exploring this in more detail. But on a V1 for example, even at 1024 x 768 the desktop is very blurry. In games there is also a difference. But as always, if you don't have them side by side it is hard to see what could be improved. But the V3 clearly has a better image.
My YouTube channel
Reply 22 of 29, by AlphaWing
VB\V3 is sharp.
Clearer then NV cards until you reach the FX line, which from what I remember, has parts of the 2d tech took from the 3dfx remnants that NV acquired.
Reply 23 of 29, by vlask
You can add to the broken games list Alien vs Predator Gold edition - same problem with textures....
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 24 of 29, by leileilol
V2's broken AVP is due to a regression in the DX7 beta+ video drivers. Using the earlier DX6 v2 driver (even when you have DX7 or newer installed) won't have this issue
long live PCem
Reply 25 of 29, by dr.zeissler
Thx Phil, that is EXACTLY my problem, BUT it depends on the programm.
Some D3D Games do not make glitches with a P3-600, others look like this.
OpenGL/Glide is fine though.
I do not know, what the real difference is.
Please test these two D3D Tests. One is fine the other produces the texture glitches. (with the latest 3dfx-v1-ref-driver)
    PCP-D3D.zip
    178.52 KiB
    65 downloads
    GST-D3D.zip
    396.03 KiB
    69 downloads
    496.56 KiB
Reply 27 of 29, by dr.zeissler
It's not that thing about comparison, it about that issue with the v1 in faster systems.
In my case it's only a D3D problem and it depends on the game, so it's possible fixable.
Doc
Reply 28 of 29, by derSammler
It is! It's clear from the beginning that a Voodoo1 has no chance in a system powered by a Pentium II 400 or faster. A much slower CPU already has enough power for software T&L to hit the Voodo1's limit. If at all, such a test should rather find the sweet spot for a Voodoo1 by starting with a fast 486 and then testing with faster CPUs unless the one is found which no longer gains more fps.
Reply 29 of 29, by dr.zeissler
I can only put a v1 in that case!!!! I cannot get my hands on a canopus voodoo2 that is short enough.
I cannot downgrade the cpu either!!!! the lowest supported cpu is a cel-533.
So I have to stick to the voodoo1 and the onbaord i815e and both are VERY good.
I did some more investigating and I am now sure that it is the 8-bit palletized textures in D3D!!!!
If this can be fixed the voodoo1 will be fine in my P3-600.
