Attempt to solve FILES= problems
Reply 20 of 35, by Supertool
Hardball 5 during install says it needs Files=30 in config.sys. It won't install. I am using dosbox under gentoo linux.
Reply 21 of 35, by PowerMatt
Team F1 (aka Pole Position) requires FILES=40.
Reply 22 of 35, by flynnieboy
IIRC, T2 Arcade Game requires FILES=10. Never managed to get that ***** work on DosBox 😉
Reply 23 of 35, by konsultor
The DOS contact manager ACT (ver. 2.11) says it needs FILES=40 when it fails to start.
Can send a copy; it is 391 KB.
Would DEARLY love to get this running on Linux (Debian/Linspire).
Thanks.
Reply 24 of 35, by konsultor
ACT (the contact manager) for DOS wants 40 files.
You had that info, just a friendly reminder. 😉
Reply 25 of 35, by DosFreak
As of the current CVS Battlecruiser 3000 v2.0 demo now loads.
Previously would get a FILES error.
Game doesn't work past the main menu screen but hey at least it loads now.
Edited by mirekluza: replaced reference to 0.63 by the current CVS. 0.63 is not released yet. You are confusing newbies. 😀 . The latest officiall version is still 0.62.
Make your games work offline
Reply 26 of 35, by priestlyboy
As of current CVS (aka 0.63rc1 Unofficial non-public release)
Stonekeep 1.2 no longer needs the win95 switch to load 😀.
It also seems to run better 😀 but that could just be from my happiness.
Ieremiou
Helping Debug DOSBox.
Reply 28 of 35, by tie
hey robert how u do the tie fighter??? u using the d-fend??? i cannot seems to get it work on tie fighter..... pls help me !!!!
Reply 29 of 35, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
uh oh, you are hijacking an ancient thread for a "how to get game xyz running" and that in the developer section. You better use the search and respect the posting guidelines.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 31 of 35, by rcblanke
@Dosfreak: confirmed, has worked earlier. Works in ykhwong's version though...
Reply 32 of 35, by rcblanke
Neverlock now works in CVS again.
Reply 33 of 35, by DosFreak
Neverlock not working in 3-17 CVS.
"Univeral Neverlock Spring 96"
Not enough file handles available.
Put Files=25 in the CONFIG.SYS.
Clicking around with the mouse while the above error is shown also results in a nice frozen DosBox. 😀
Reply 34 of 35, by zajec5
Application that doesn't start because of FILES= problem is "Subiekt". It's polish application so for a case you would like to ask me for translating polish→english I made a separate thread: Subiekt and FILES=
Reply 35 of 35, by dosgremlin
STONEKEEP IMPORTANT NOTE RE: FILES=15
This error WILL occur when you run stonekeep from a CDrom mount. The software tries to open files with read/write access and when it fails w/access error, it reports the FILES = 15 error.
Create a c: 'harddrive' mount and a separate d: 'cdrom' mount, and make sure you're sitting in c: when you run the executable. Failing to do so WILL result in a FILES = 15 error.
The 'win95' parameter seems to make no difference here as long as you execute from a harddrive mount with files that are not read-only.
- DosGremlin
