Reply 21 of 97, by Darkman
- Oldbie
just one question , in Quake 2 , which texture quality did you use ?
Reply 22 of 97, by PhilsComputerLab
Reply 23 of 97, by Darkman
- Oldbie
wrote:wrote:just one question , in Quake 2 , which texture quality did you use ?
Default settings. So whatever that is 😊 The only setting I changed was render mode to default OpenGL and the resolution.
cool , sadly I dont own forsaken that cant be benchmarked, but I can benchmark a few other games like MDK2 (which is one of the first games to really favour the Geforce due to having hardware T&L)
Reply 24 of 97, by PhilsComputerLab
Reply 25 of 97, by Darkman
- Oldbie
wrote:Really, Unreal and UT are the main ones, seeing they use Glide.
The version I used is the DVD Unreal Anthology.
not sure if that makes a difference, I use the original boxed version (not even the GOTY version) but with the latest official patch , so it should be the same really.
Reply 26 of 97, by PhilsComputerLab
Reply 27 of 97, by meljor
interesting, would like to see that acer board vs the Tusl2-c
Reply 28 of 97, by F2bnp
- l33t
wrote:Yea, doubt it makes much of a difference, if any.
AFAIK, Unreal Gold used an updated engine, straight off of UT. So, if you were to compare Unreal Gold vs Unreal vanilla, especially on lower resolutions, I believe vanilla would have a slight edge. But it is of no matter, since the framerates would already be skyhigh. 😀 I'll be benchmarking in a while and post the results later today. I expect my VIA board to be trailing the Intel boards at 640x480 and 800x600, but I think on higher resolutions there should parity between the boards and results within margin of error.
Reply 29 of 97, by Darkman
- Oldbie
benchmarking in Windows 2000 complete , Win2K SP4 was used , along with the standard 3DFX drivers.
GLQuake
640X480 - 337.1
800X600 - 234.6
1024X768 - 154.3
1280X1024 - 102.6
1600X1200 - 72.7
Quake 2
640X480 - 182.2 3DFXGL - 242.3
800X600 - 145.1 3DFXGL - 202.6
1024X768 - 105.4 3DFXGL - 145.6
1280X960 - 73.0 3DFXGL - 100.6
1600X1200 - 42.1 3DFXGL - 66.5
Unreal
640X480 - 153.97
800X600 - 137.14
1024X768 - 108.75
1280X1024 - 73.07
1600X1200 - 51.80
UT99
640X480 - 99.44
800X600 - 98.55
1024X768 - 94.40
1280X1024 - 74.40
1600X1200 - 54.08
For Quake 2 I ran both Default OpenGL and 3DFX OpenGL , since the Default values seemed very low for some reason.
interesting to see the diffrences between Win98SE and Win2000 , the CPU seems to be taxed more at lower resolution in W2K , whereas the results are almost identical at higher resolutions (could be because Win2K puts a bigger load on the CPU in general , or 3DFX's Win2K drivers probably being pretty early)
Some other benchmarks I ran
Quake III (all maxed settings at 1024X768) - 77.4 fps
3Dmark01 - 2219
Final Reality
2D Image Processing - 13.85
3D Performance - 8.28
Bus Transfer Rate - 7.01
Overall Score - 9.76
Now for the performance of the U160 Seagate Cheetah drive in this machine
so far this is it.
Reply 30 of 97, by PhilsComputerLab
- l33t++
Very nice results Darkman. That SCSI drive is very impressive I must say.
wrote:interesting, would like to see that acer board vs the Tusl2-c
So would I, could you send me one please? 😊 🤣
wrote:wrote:Yea, doubt it makes much of a difference, if any.
Cheap way to get Unreal Gold is the GOG version. If it's on sale. Use a reverse installer to unpack it, remove the filed for the glide wrapper and you're good to go 😀 I also got the DVD version. For some reasons there are a ton of UK sellers, selling old PC games, NIB for little money. Got quite a few that way 😀
Reply 31 of 97, by F2bnp
- l33t
Phil, is the Forsaken benchmark running at 16bit color or 32bit? Ran it once at 640x480x16, but Vsync seems to be enabled and I only got 75FPS, any idea on how to get rid of that?
Reply 32 of 97, by PhilsComputerLab
- l33t++
wrote:Phil, is the Forsaken benchmark running at 16bit color or 32bit? Ran it once at 640x480x16, but Vsync seems to be enabled and I only got 75FPS, any idea on how to get rid of that?
I think 16 bit colour.
Yes, the driver has V-Sync on for DX games. You need to run the overclock tool (it's an official tool from 3dfx). It adds another page to the driver and here you can disable V-Sync for DirectX games.
Reply 33 of 97, by Darkman
- Oldbie
hmm, I went ahead and quickly tested a couple of games in Win98SE , and the numbers were actually identical to Win2K
meaning there is something slowing down this PC by a bit, will have to find out what is it.
Reply 34 of 97, by PhilsComputerLab
- l33t++
I wouldn't drop any sleep over this. Apart from using the tightest memory timings, what else can you do?
What chipset driver did you use? I went with an older one. 2001 driver from here: http://www.philscomputerlab.com/intel.html
Reply 35 of 97, by F2bnp
- l33t
Timings/BIOS Settings etc.
Could someone upload or direct me to the latest version of ATTO benchmark that will work with Win9x? 2.41 and 2.47 won't run 🙁.
Reply 36 of 97, by Darkman
- Oldbie
I think I used one from 2004 , I will try out the various ones , and see what results I get
Reply 37 of 97, by Skyscraper
This is a very nice build 😀. I wish I soon find a cheap Voodoo5, they always end up going for more than Im willing to pay.
The PIII 1400-S sure is popular among us VOGONers 😁
Reply 38 of 97, by PhilsComputerLab
- l33t++
wrote:This is a very nice build 😀. I wish I soon find a cheap Voodoo5, they always end up going for more than Im willing to pay.
Yes they cost a small fortune. I got mine from an Australian collector. He sold up everything on eBay, so I grabbed a V4 and V5 and he did free shipping 😀 It wasn't cheap, but the prices aren't going to come down and you can wait forever.
wrote:Timings/BIOS Settings etc.
Hmm 2.41 should work. Here is an older screenshot I took:
Alternatively try Disk Speed. While it doesn't test write performance, it does test random reading and also access time.
Reply 39 of 97, by Darkman
- Oldbie
well , Ive tried several chipset drivers for both Win98SE and WIn2K.
Win98 did benefit from the older drivers, lower resolution results are higher. On the other hand, Win2K shows no improvement , and was actually slightly worse in performance, meaning I settled on the 2002 drivers as a compromise.
As far as BIOS and memory timings , the RAM in this is already at CL2 , and while this Intel board is rock solid in terms of stability, it has relatively few tweaking options.
though of course, if the games already run at 200+ fps, a couple of frames here or there arent going to make a difference.
