First post, by PhilsComputerLab
- l33t++
Link to YouTube video: Building the Ultimate 3dfx Voodoo 5 Glide Gaming PC
In this video I am building the Ultimate 3dfx Voodoo 5 Glide Retro Gaming PC. This PC is a beast, delivering high end performance in Glide, OpenGL and DirectX games from the golden era of early 3D games. Storage performance is also impressive, achieving over 80 Megabytes per second.
The video features time lapse of me putting everything together. I talk about the parts I use, put everything together, tweak the BIOS, install Windows and drivers and finally show some benchmarks of the hard drive, Unreal, Unreal Tournament, GLQuake, Quake II and Forsaken.
Acer OEM S370 board with i815 chipset and StarTech CPU cooler
OEM boards often get neglected. I have two of these Acer boards, and they are faster than the Gigabyte GA-6VTXE and the AOpen MX3S-T. The BIOS has plenty of options, even allowing you to set memory timings. Very stable and had no issues with it.
Intel Pentium III-S 1.4 GHz Tualatin 512 KB Cache
The Pentium III "Top Dog" so to speak. Doesn't get any better and bests the early Intel Pentium 4 processors.
StarTech CPU cooler
Rated for Pentium III 1.4 GHz and having three latches on each side, spreads the load better than other coolers.
512 MB SDRAM PC133
Rated at CL3, but does CL2 no problem. Got to have some RAM, 512 MB max for Windows 98 SE.
AGP Voodoo 5 5500 power
What can I say? It's big, hungry, fast and beautiful. The fastest Glide card around and made for games such as Unreal.
Diamond Monster Sound MX300
Diamond's cult classic sound card with Aureal's Vortex 2 chip and A3D surround over headphone technology.
120 GB SATA III drive
You know this was coming. I love using modern SATA III drives, limiting the capacity with SeaTools and using SATA to IDE adapter and the onboard IDE controllers.
SATA to IDE adapter
Configured to Master. Not much to say, it gets the job done.
Look at that storage performance!
IDE DVD-RW
Configured as slave and connected to the same IDE channel as the hard drive.
GOTEK Floppy emulator
Can't go without it. It's cheap, reliable, looks nice, 100 images on a USB stick, why wouldn't you want to use one?
The finished PC
Looks like a generic computer. But turn it on and be amazed at the Glide 3D performance this beast delivers!
Benchmarks
Delivering, fast, smooth and beautiful frames to your brain.
