No, definitely not. Live Is a good card (most versions anyway, definitely including 4760) and would be also my choice for a PIII […]
RavenholmDX wrote:philscomputerlab wrote:+1 for an Aureal Vortex 2 PCI card. Works very well under DOS, and even has a wavetable header.
I just pulled the trigger on a SB Live CT4760. I looked into the Aureal Vortex2 and it doesn't seem as readily available, or as cheap. I got the SB Live for about 6GBP. Mistake?
No, definitely not. Live Is a good card (most versions anyway, definitely including 4760) and would be also my choice for a PIII based pure Windows 98 setup.
One question is still there: Do you want to play dos games? If the answer is yes, I would definitely suggest AWE64. You will give up EAX, but for the price of much better DOS compatibility, infinitely less hassle, more than very acceptable sound quality (well, IMHO).
EDIT: Forget about AWE64, I just realized that your choice of motherboard does not have any ISA slots. 🤣
