Reply 20 of 53, by boxpressed
- Oldbie
It looks like I will need another three-pin connector for the SDRAM headers. Luckily, this case has another three-pin connector that goes to the LED display. Because I'm fine leaving the display at 550, I'll just replace it with a regular jumper. Unfortunately, I may have to take the mobo out of the case to access the panel, so I won't be able to test for a while. Turns out that this particular case--with a pair of three pin connectors wired to the turbo button--might be the perfect one for building an all-in-one.
