Reply 20 of 24, by NooNaN
- Member
Phil - I think I'm going crazy. Yes, just basically need an audio switcher, that's it. For some reason I was dead-set on thinking I needed a MIDI IN, MIDI OUT type of a switcher. Clearly, I don't.
This is what I'm running with now:
I currently have the output from my AWE32 into the MIDI Splitter, then out to the MIDI devices, then to the mixer.
EDIT - Phil, one more follow up question...when you mentioned mixing MIDI, SB and CD Audio, what did you mean by CD Audio? Are you somehow taking the CD audio out/away from the SB and converting to RCAs?
The Rolls MA254 looks interesting...too bad I pulled the trigger on the MiniMix too quickly. Anyone interested in it if I replace?
