Matrox G2+ What Type Of Memory Does It Need?
Reply 20 of 24, by Errius
This needs testing!
"AI Requires Proof That You Are Human"
Reply 22 of 24, by Rawit
swaaye wrote:
I think adding RAM reduces memory clock speed. That would be undesirable. 😀
From what I've heard/read adding memory keeps the clock/memory clock at 84/112 which is default for most cards, so overclocking won't work, but there wouldn't be a performance drop. But there are stock G200's out there that have been clocked higher and I'm not sure what happens when memory is added to those.
YouTube
Reply 23 of 24, by swaaye
The info is in the so-called pins that they used to configure the BIOS. You are right that typically the clock isn't reduced. I saw one G200 that did however, but it also runs slightly higher memory clocks normally than the others for some reason. With memory expansion, it went down to a clock typical for the other cards.
This old site has a collection of BIOS pin data among other things. See the BIOS section.
https://web.archive.org/web/20040110103309/ht … .pl/gbm/matrox/
One can also overclock cards by flashing modified pin data.
