Reply 20 of 28, by duga3
Benchmarks, coming right up!
Game tests / settings
F.E.A.R. - 800x600
Game Version = v1.0 - Retail
In-game / Benchmark = Max details
Benchmark Scene = Default
NVPI = Defaults
F.E.A.R. – 1600x1200
NVPI = Defaults
F.E.A.R. – 1600x1200 – 8xSGSSAA
NVPI = Defaults
NVPI, Antialiasing compatibility = 0x004010C1
NVPI, Antialiasing - Behavior Flags = None
NVPI, Antialiasing - Mode = Override any application setting
NVPI, Antialiasing - Setting = 8xQ [8x Multisampling]
NVPI, Antialiasing - Transparency Supersampling = 8x Sparse Grid Supersampling
NVPI, Anisotropic filtering mode = User-defined / Off
NVPI, Anisotropic filtering setting = 16x
F.E.A.R. – 1600x1200 – 4x4SS
NVPI, Antialiasing - Setting = 4x4 [4x4 Supersampling (D3D only)]
Far Cry 2 - 800x600
Game Version = V 1.00
Benchmark Scene = Ranch Small
NVPI = Defaults
Far Cry 2 – 1600x1200
NVPI = Defaults
Far Cry 2 – 1600x1200 – 8xSGSSAA
Far Cry 2 – 1600x1200 – 4x4SS
Configurations
875K + 960           = CPU @ 2930 MHz. RAM @ 1333MHz. GPU @ 1304 MHz core, 3505 MHz memory. Windows XP 32-bit.
875K + 980 Ti = CPU @ 2930 MHz. RAM @ 1333MHz. GPU @ 1430 MHz core, 3548 MHz memory. Windows XP 32-bit.
875K OC + 980 Ti = CPU @ 4135 MHz. RAM @ 1600MHz. GPU @ 1430 MHz core, 3548 MHz memory. Windows XP 32-bit.
875K + 980 Ti OC = CPU @ 2930 MHz. RAM @ 1333MHz. GPU @ 1610 MHz core, 4104 MHz memory. Windows XP 32-bit.
875K OC + 980 Ti OC = CPU @ 4135 MHz. RAM @ 1600MHz. GPU @ 1610 MHz core, 4104 MHz memory. Windows XP 32-bit.
4690K OC + 1080 Ti = CPU @ 4698 MHz. RAM @ 2133MHz. GPU @ 1860 MHz core, 5508 MHz memory. Windows 7 64-bit.
Details
875K Overclock - BIOS Settings
Frequency/Voltage Control
Memory Configure
DRAM SPD = XMP Profile 1
DRAM Frequency = 1600 MHz (2:12)
DRAM tCL = 7
DRAM tRCD = 8
DRAM tRP = 7
DRAM tRAS = 20
CPU Configuration
MPS and ACPI MADT ordering = Modern ordering
Intel(R) HT Technology = Enabled
Active Processor Cores = All
C1E Support = Disabled
Intel(R) SpeedStep(tm) tech = Enabled
Intel(R) TurboMode tech = Enabled
Turbo Ratio Limit Program = Enabled
1-Core Ratio Limit offset = 0
2-Core Ratio Limit offset = 0
3-Core Ratio Limit offset = 0
4-Core Ratio Limit offset = 0
Turbo Limit current Override = Disabled
Turbo Limit power Override = Disabled
Intel(R) C-STATE tech = Disabled
K Boost = Enabled
CPU Multiplier Setting = 31
CPU Frequency Setting = Auto
PCIE Frequency Setting = 100
QPI Frequency Seletion = Auto
MCH Strap = Auto
EVGA VDroop Control = With VDroop
Bootup CPU VCore = 1.40000V
Eventual CPU VCore = 1.40000V
DIMM Voltage = 1.65V
Bootup CPU VTT = 1.400V
Eventual CPU VTT = 1.400V
PCH = 1.400V
CPU PLL = 1.900V
875K Overclock - CPU-Z
115.85 KiB
980 Ti Overclock - MSI Afterburner
448.63 KiB
98/XP multi-boot system with P55 chipset (build log)
Screenshots
10Hz FM
Reply 21 of 28, by duga3
Results - F.E.A.R.
(Min - Avg - Max FPS)
F.E.A.R. - 800x600
15.46 KiB
15.04 KiB
15.75 KiB
15.01 KiB
Screenshots
10Hz FM
Reply 22 of 28, by duga3
Results - Far Cry 2
Far Cry 2 - 800x600
15.21 KiB
15.5 KiB
15.64 KiB
15.64 KiB
Screenshots
10Hz FM
Reply 23 of 28, by mothergoose729
Interesting results! Keep them coming!
It looks like a GTX 960 or equivalent is ideal for later windows XP gaming - for max settings at 1600x1200 - but when you add in extreme forms of AA and super sampling you can justify up to a 980ti.
Using a CRT monitor, because of the limitations of the dot pitch and of the tech, I find that 2x super sampling is just as good as 4x or more. I just can't get more detail out of my 17inch CRT because there aren't enough phosphors. Using an LCD panel at 1080p, I find I need 4x super sampling to completely eliminate aliasing .
Reply 24 of 28, by duga3
mothergoose729 wrote on 2021-02-12, 19:24:
I was (again) testing downsampling from 16K to 4K (2880x2160@60Hz) the other day on a 21" CRT and that's around where things start to look really good in motion. CRTs are very sharp in motion so you can see every tiny bit of shimmering, especially tree leaves in the distance and such. Regarding native CRT resolution, 1280x960 is imo the cut off when you stop noticing the "pixels" or scanlines or whatever. At least on 21" CRT. So if your CRT can do at least that then downsampling/AA should be really beneficial.
If you look at mere 720p movies you can barely see any "pixels", that's because the real world has infinite amounts of downsampling so to speak. So 720p movies just look a little softer than 1080p.
The takeaways from those tests for me and this build are that:
- even 980 Ti is not enough to really max out the late-era Windows XP games
- while a lot of these games work in Win7 they will show little glitches in audio or video department. Usually nothing you would notice unless comparing side by side, but if you are after the original (yet maxed out) experience then it kind of counts.
- you need super fast AND overclocked CPU to play these games at high refresh rates (assuming you are not bottlenecked by GPU, which you are usually not at lower resolutions). The 875K CPU I have there now is too slow for this type of use. After overclocking the 875K there was still "only" ~130FPS in Far Cry 2 (with no extra eye candy from NVPI, at 1600x1200).
Thankfully there is not really that many computationally/graphically intense late-era Windows XP games.
So to sum up, I am happy that 980 Ti from 2015 can still be used in Windows XP but not super excited because it does not max out what NVPI offers (although only in a few later titles). 875K not so much, it is here only because of the P55 motherboard, which has been great so far, and of course allowed me to do this kind of build in the first place. If I will run into a lot of compatibility issues with older games under 980 Ti (haven't really tried many of those yet) then I might as well replace it with for example 780 Ti or older here and then build a dedicated rig with 980 Ti and a much better CPU (is his how it starts?!). But for now it stays as I have nothing bad to say about it.
Screenshots
10Hz FM
Reply 25 of 28, by bestemor
duga3 wrote on 2019-08-07, 21:45:
W98:....
Good news is that I was able to solve the disk speed issue after installing RLoew SATA patch and doing some specific configuring in BIOS and Device Manager with his great help. The speed increased from 7MB/s to upto 215MB/s. Amazing. It also made the SATA CD-DVD drive work (which I didnt really pay attention to before).
Just wondering, for future reference, what exact configuring had to be done here ?
(have a 'plan' about a build, and am gathering background knowledge before starting, never having used any Rloew programs before, and expecting them to be somewhat cryptic...)
Reply 26 of 28, by Hanamichi
I remember when I had a Titan X Maxwell, there were rumors VGA performance was degraded compared to digital signals.
Very strange but it did feel like that, might be worth checking with a benchmark and then you could always use a DP -> VGA converter if it is a massive difference.
I find the output of analogue VGA is a bit subpar on the Maxwell and to a lesser extent Kepler, my Delock DP -> VGA seems clearer for high res.
On the other hand something like a <GTX 580 or HD7970 has lovely VGA quality.
Just another thing to consider for the ultimate build 😁
Reply 27 of 28, by pentiumspeed
Lucky guy to have Kingpin card. Fully copper heastsink. Not easy to find like one and I rather prefer that type. I was lucky to get two GTX 580 Classified cards, one needed repairs but got working.
Cheers,
Great Northern aka Canada.
Reply 28 of 28, by duga3
bestemor wrote on 2021-05-02, 16:23:
W98:....
I was meaning to do it myself at some point because yes, the SATA patching was rather cryptic, at least for me. It is an email conversation. I can clean it up, focus it only on the specific technical bits and post it -> but where? Would be offtopic in this thread. If you or anyone has ideas for a proper place, please send me a PM.
edit: I will try to remember to update this reply with a link, once it is posted somewhere.
Hanamichi wrote on 2021-05-03, 16:50:
I remember when I had a Titan X Maxwell, there were rumors VGA performance was degraded compared to digital signals. […]
I always had this feeling that the older cards were crisper somehow but never really believed it or tested it. It could just be that Win7+ UI and text looks really soft on a CRT.
pentiumspeed wrote on 2021-05-06, 01:36:
Cheers,
Yeah, the copper is real nice and the card is quite heavy so it has that high quality hefty feel. It is a little over engineered which makes it interesting, check out https://xdevs.com/guide/maxwell_big_oc/
Screenshots
10Hz FM
