Reply 20 of 28, by Sphere478
I looked, this case uses a pcb with micro buttons
I have one of these though, will have to check what kinda switch it has
Sphere's PCB projects.
Reply 21 of 28, by Sphere478
Lack of drive bays is proving annoying. Lol
Any ideas for adding drive bays?
Gotek, but in a card slot?
Reply 22 of 28, by weedeewee
Sphere478 wrote on 2022-05-27, 06:50:
both power & reset tend to be momentary switches, not latching ones.
Do not ask Why !
Reply 23 of 28, by Sphere478
I know, I meant what form factor the switch is.
It’s a micro button.
Are there any latching microbuttons?
Reply 25 of 28, by pentiumspeed
Power on pin on ATX PSU is pulled high internally in PSU's side when off. Motherboard pulls this low and held low ground as long as PC is on. Not signal. This is control pin. For this, this is safely done with a latching push button or toggle switch hooked to this and ground to power anything that is not ATX motherboard.
Cheers,
Great Northern aka Canada.
Reply 27 of 28, by weedeewee
Sphere478 wrote on 2022-05-27, 21:11:
If it is like 1 , then no
if it is like 2, then yes.
    3.04 KiB
    3.02 KiB
Do not ask Why !
Reply 28 of 28, by Sphere478
Like this file.php?id=138313&mode=view
weedeewee wrote on 2022-05-28, 06:35:
