First post, by Sphere478
Okay, I’m gonna make a new build.
-I want it to be able to fit a long baby AT (tyan s1564), or a full ATX mobo (no need for extended atx)
-it must be as small as possible
-mostly or all metal construction. I don’t like plastic.
-a window would be nice.
- this one is gonna make things tricky.. Prefer a laptop size cd drive just because it helps the case be as small as possible.
298.09 KiB
I found the cooler master q500l that seems to check a lot of the boxes but not all.
Any suggestions?
Sphere's PCB projects.
Reply 1 of 28, by chiveicrook
Long baby AT + full ATX and "as small as possible" are somewhat contradictory. Are slim cases a consideration or do you need full height card compatibility?
Anyway, Silverstone FT05 would tick almost all boxes but it supports "up to" SSI CEB form factor and Tyan S1564 might not fit in there.
EDIT:
PS. I don't think q500l can actually fit Tyan S1564: I'm pretty sure PSU will get in a way.
Reply 2 of 28, by Sphere478
chiveicrook wrote on 2022-05-21, 07:26:
Long baby AT + full ATX and "as small as possible" are somewhat contradictory. Are slim cases a consideration or do you need ful […]
EDIT:
Full height cards are gonna be required 🤔
Reply 3 of 28, by paradigital
I think the best way to stay compact with full ATX is for a case that hangs the PSU over the motherboard, but then that will limit CPU cooler height.
Reply 5 of 28, by The Serpent Rider
Silverstone Raven 2 or Fortress 2. Both can fit standard SSI-CEB server motherboard, which are roughly the size of full Baby AT.
Reply 6 of 28, by weedeewee
I've always wanted to build my own case, and my idea would be more cube like, divided in two parts, one for the mainboard and expansion card, the other for the psu, hdd/ssd/cd/dvd/bd/fdd/tape/...
footprint would be slightly larger than a EATX mainboard. Smaller versions with a footprint of ATX or µATX or mITX or... are also an option. For ease of access and easier/quieter cooling solutions, bigger and more spacious is better.
Then comes the question of leaving the mainboard on a side or the ground plane, though that would be down to personal preference.
I've seen cases that come close to this idea, though no idea what name/brand they are, nor where to find'm.
Do not ask Why !
Reply 7 of 28, by Plasma
weedeewee wrote on 2022-05-22, 11:58:
I've always wanted to build my own case, and my idea would be more cube like, divided in two parts, one for the mainboard and ex […]
Sounds like the Cooler Master HAF XB.
Reply 8 of 28, by weedeewee
Plasma wrote on 2022-05-22, 16:18:
Great find.
If it weren't for the protrusion on the top, the fact the case wasn't made to be put on its side and the annoying space to fiddle with the cables for hard drives etc... That would be a great case.
Do not ask Why !
Reply 9 of 28, by Sphere478
That looks like a good design. It seems like they could have made it smaller on the top and bottom side of the mobo. Maybe pull cables from the front.
Reply 10 of 28, by Unknown_K
weedeewee wrote on 2022-05-22, 17:05:
Great find.
Well the drives go in the front removable bays so you don't need to fiddle with the cables once they are installed. I have one of those and like the built in handles on the side plus the super large fan on top.
My only issues is it can't use E-ATX boards but full ATX work fine. Also the front facing fans are not easy to clean.
Reply 11 of 28, by weedeewee
Unknown_K wrote on 2022-05-24, 03:20:
There also seems to be 2, 3? internal bays, that would still require fiddling with the cables.
Also sort of decent cable routing always requires some fidgeting.
for me the lack of E-ATX support is a bit sad, and a full size fan on top...
I want to stack a 24" CRT monitor on top (if I ever get one, all I have atm is a 19 or 21" one) 😁
and since you have such a case, is it possible to add filters before the fan intakes ?
Do not ask Why !
Reply 12 of 28, by The Serpent Rider
With the power of HANDS, everything is possible.
Reply 13 of 28, by weedeewee
The Serpent Rider wrote on 2022-05-24, 15:27:
Pretty sure that adding hands to the fans will result in a high Auch factor and bad airflow.
Do not ask Why !
Reply 14 of 28, by Grem Five
It is sad, about a year ago these things cost $105 new on newegg so I looked at getting one and dragged my feet. Well I got more serious to get one about 3 months ago and the newegg price had jumped t0 $125 and this was for a case that they have stopped making. Personally I didnt think it was worth the jump in price so I went in another direction.
Reply 15 of 28, by Unknown_K
Case prices jumped up like crazy during the pandemic because of supply side issues.
I snagged my HAF XB case a few years back used for $20-25 locally along with half a dozen other gaming cases figuring I would be set for life, but nope. I prefer cases with dust filters since they make life easier (for air intake and for power supply intake). I still like the case and working inside with the lid off is easy going.
Reply 16 of 28, by Sphere478
Lookin good so far..
    1.96 MiB
    1.85 MiB
Reply 17 of 28, by Sphere478
Turning into a fun build.
Reply 18 of 28, by Sphere478
Any suggestions on a latching switch I can use for the main switch?
I suppose I have to take it apart and see what kinda switch it’s using.
This gives me a idea for a rear i/o project. A card that plugs in the AT spades and the atx pin header and gives a latching power button feature
Reply 19 of 28, by weedeewee
Sphere478, measure the current the ps-on signal does, and if low enough, use the latching microswitch that old cases have for the turbo button.
Do not ask Why !
