Maj.Jackyl's Computer Lab
Reply 200 of 201, by Major Jackyl
So, I've set this LuckStar up three times now and have full function every time. No clue what was going on.
The attachment A845S_P41700.JPG is no longer available
The POST card effects nothing. This last time, I installed the wrong video card, but still functioned perfectly (just way faster). I even added a network card and transferred about 16GB of games. Definitely going to call this GOOD and add it to the collection.
The attachment 20251021_165423.jpg is no longer available
Over the weekend I cleaned and benched a Shuttle FB61 with Pentium 4 SL6WK (3.0/800/512), 2x1GB DDR400, and a very similar Radeon 9600.
The attachment Shuttle_Fb61_P43k_R9600.JPG is no longer available
I had to use my normal bench PSU (300W Enermax), since the 200W PSU in the Shuttle had plague™ and was broken, most likely from not being powerful enough. It's going to get a nice 350W retrofitted (needs ATX and P4 connectors).
ANYWAY, to the point: it was a similar setup to what I was messing with earlier and now that I got the 9600 in the board, I can compare the "same" video card in two similar systems with wildly different CPU clocks and memory, especially since the LuckyStar has 133Mhz SDRAM. The results are expected, but now quantified.
The attachment A845S_P41700_R9600.JPG is no longer available
I had my brothers' Shuttle race my Shuttle, for funsies; mine got blown out of the water. Of course, it DID finish first, but not a fair race, as the GF4 was missing many feature tests. My Shuttle runs Athlon 64X2-3800+(2.0Ghz) 2x512MB DDR400, and GeForce 4 MX4000. I didn't get pictures of his while it was here, but it was way slicker-looking than mine, with a 2mm aluminum plate on the front.
The attachment FN95_MX4000.JPG is no longer available
Going to do a recap now. Not sure what, but it's going to get done, 🤣
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 201 of 201, by Major Jackyl
I decided to do PCChips M861g(1.6a) because it looked like I could get it done quickly, not many caps.
The attachment 20251004_152520.jpg is no longer available
I initially was just going to to the power stage, it had some puffers, but I ended up doing the whole thing. 34 on this one. Most of them tested fine, just the puffers were actually bad.
The attachment 20251021_205321.jpg is no longer available
The attachment 20251021_205332.jpg is no longer available
The attachment 20251021_205357.jpg is no longer available
I'm about to test it soon. If it works, I'll prepare a drive for it. I recently got a pile of 40 and 80 GB Seagate 7200.7, so I've been pairing boards to drives.
The attachment 20251021_211401.jpg is no longer available
