VIDEO Patch for pixel-perfect scaling (SDL1)
Reply 200 of 733, by Ant_222
lightmaster wrote:
I think it' an interesting proposal, hope it works for steam and gog releases to capture screenshots too.
I don't know about GOG, but Steam can take screenshots from ddraw output only, whereas my patch currently works with surface. It can be extended for ddraw but I am not yet working on that.
Reply 201 of 733, by Yesterplay80
lightmaster wrote:
I think it's an interesting proposal, hope it works for steam and gog releases to capture screenshots too.
Aren't screenshots and video captured in the game's orginal resolution and aspect ratio anyway? At least if you use the built-in capturing (Ctrl+F5, Ctrl+Alt+F5)?
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 202 of 733, by KainXVIII
Not ddraw, but only opengl or direct3d (some games has optional dosbox ykhwong build).
But i found the way to upload custom screenshots (from dosbox capture folder), its not very convenient, but it works 😀
http://steamcommunity.com/id/KainXVIII/screen … &view=imagewall here is my gallery from Harvester, some screenshots from ykhwong build, some from latest svn of dosbox with pixel-perfect scaling, you can tell the difference 😀 Also you can see, that fmv movies screenshots (which are 320x200) not scaled properly, as mentioned by Yesterplay80
Also i don't think that GoG or Steam will update their games to new dosbox UNTIL it updates itself to new version (ie 0.75)
Reply 203 of 733, by lightmaster
Are you sure? i always use(d openglnb for screenshots.
Cheers
Reply 204 of 733, by lightmaster
I guess so, but i'm not 100% sure.
Reply 205 of 733, by Ant_222
lightmaster, I misremembered about the screenshots. You are correct. Edit: If I shall be extending my patch, I shall make it orthogonal to output type, so that it shall work with any output.
Reply 206 of 733, by lightmaster
Np Ant_22, Bravos 'n' claps for your work!!
Reply 207 of 733, by Ant_222
Thank you kindly!
I have just uploaded the alpha 9 version of the patch, which changes the defaults as discussed. To test it, delete the configuration file before running the patched version. Then invoke
config -wc
from within DOSBox prompt to generate a fresh config with the new defaults.
Reply 208 of 733, by Yesterplay80
Enhanced build is updated with your alpha 9 patch.
Reply 209 of 733, by Ant_222
Thanks a lot—let us see whether the new defaults work for everybody.
Reply 210 of 733, by Yesterplay80
They don't work here, I always get the old defaults when creating a new conf file (fullresolution=original, output=surface).
Btw.:
const char* outputs[] = {
- "surface", "overlay",
+ "surface", "surfacepp", "surfacenp", "surfacenb", "surface",
I think that's one "surface" to much and one "overlay" missing there. 😉
Reply 211 of 733, by Ant_222
Yesterplay80, did you remove the old config file before running the patched version?
Reply 212 of 733, by Yesterplay80
Yes, I did.
Reply 213 of 733, by Ant_222
I have justed it with your build, and it worked for me, generating a correct config file. I used the archive named DOSBox SVN r4000 enhanced.7z
Reply 214 of 733, by Ant_222
Yesterplay80 wrote:
Btw.: […]
Btw.:
I think that's one "surface" to much and one "overlay" missing there. ;)
It is probably my bludner. I will check it in the evening. That should not prevent DOSBox from generating the config file with new defaults.
Reply 215 of 733, by Yesterplay80
Huh? It worked here now, too. Maybe I accidently used an older DOSBox.exe. Sorry! I updated my build again, it now shows "overlay" instead of the second "surface" again in the conf.
Reply 216 of 733, by Ant_222
Yesterplay80 wrote:
I think that's one "surface" to much and one "overlay" missing there. ;) […]
Fixed in alpha 10.
Reply 217 of 733, by Yesterplay80
Ant_222 wrote:
Fixed in alpha 10.
Thanks! Enhanced builds are up to date, too! 😀
Reply 218 of 733, by Ant_222
Thank to you, too.
Reply 219 of 733, by KainXVIII
Is Norton Commander windows supposed looks so.. squished?
