Reply 220 of 780, by James-F
- Oldbie
wrote:Because you do not understand , what I said about General MIDI Level 1 aka GM. In GM must used only Standard 1 Drum Kits
Yes, according to standard you must use only Standard Kit in GM.
SC-VA will show "--------" if the patch on Channel 10 is not 1 (Standard Kit), anything else is not part of the GM standard.
Often other drum kits (Room, Power, Jazz, Orchestra, etc.) were added that are not officially part of the GM standard, but are simply there as an unofficial extension of GM drum kits.
Even "Microsoft GS Wavetable Synth" unofficially supports the additional drum kits in GM mode.
Yes they are from GS, and yes you can use them in GM, other less capable synths may not let you play other drum kits except the single Standard kit in GM mode.
As for the volume "feature request" please start a new thread.
You don't seem to be satisfied with the answer I already gave you, and simply ignored it.
Sound Canvas VA (and hardware too) is engineered/programmed so the master bus will not clip even when all instrument play together.
If you can't understand the reason in that and insist re-engineering SC-VA to your liking, tough luck deal with it.
