Reply 22700 of 31277, by liqmat
- l33t
Shponglefan wrote on 2022-09-19, 00:27:Started working on another Tandy I own, a model TL/2 I bought awhile ago but hadn't tested. […]
Oddly didn't work with my CM-11 monitor for some reason (garbled output), but worked fine with this old Packard Bell CGA monitor I had. I assumed it should be compatible with the CM-11 monitor since I've seen photos of TL/2's running on them? Or is there some settings that need to be configured somehow?
At any rate, the machine seemed to work, including the 3.5 inch drive.
I have a CF adapter and memory expansion board I may try in this one. I do lack a proper Tandy Enhanced Keyboard, so I'll have to try to pick one up.
That Tandy and PB CRT look near mint. Very nice!
