3DBENCH CPU Benchmark Database
Reply 240 of 296, by olivil
Just bought one PC100 64MB stick, my mobo does support setting up the CAS to 2. 😀 Will repost results then.
I can't fit any of those CPU as my board is not SS7 (it supports multiplier up to 5.5 and FSB up to 83MHz)
Reply 241 of 296, by Tetrium
Yes you can 😉
The main important thing is, can your board supply a low enough voltage for these chips? 2.2v and the K6-III is within your reach.
For example, you can run a K6-III/400 @ 6x66Mhz for 400Mhz (for the x6 multi, set your boards multi at 2x) 😉.
My retro rigs (old topic)
Report spammers here!
Reply 242 of 296, by olivil
My life is changed, I am a new man.
Reply 244 of 296, by olivil
Actually I went OCD and found an Asus P5A-B SS7 board with an AMD K6-2/450. 😀 Should receive it soon!
e: And a K6-2/550
e2: AND A TNT2 OH GOD WHAT IS HAPPENING
Reply 245 of 296, by Tetrium
You should try finding a K6-III. Even though the K6-2/550 is the fastest K6-2 ever released, they are still quite common (Don't we love fast retro things that are common 😀 ).
Reply 246 of 296, by luckybob
just got my 386 system up and running and 95% functional.
AMD-386DX-40-1-40-Contaq-Contaq 386-SIS 85C206-256KB-ISA-Orcid Prodesigner IIs (tseng et4000)-1MB-Luckybob-16.9
Done with a fresh install of doss 6.22 and nothing else. not even a mouse driver. I used a cyrix math-co instead of an intel math-co which might explain why my score is different than doughnut's...
Reply 248 of 296, by luckybob
as soon as I get some fresh batteries i'll post some pictures!
Reply 249 of 296, by DonutKing
I think my board is just the runt of the litter.... 😜
What sort of RAM are you using, and what wait states have you set in the BIOS?
Have you fiddled with the ISA bus jumpers at all?
Reply 250 of 296, by luckybob
i have 32mb of 60ns ram. the isa bus is set to i *think* 16mhz. I got graphical glitches at 20mhz. and I have it set to "automatic" on the memory section.
Reply 251 of 296, by sebaz_ri
Who says that the M919 is crappy???
Cyrix-5x86-60-2.0-120-PCChips-M919-UMC UM8881-None-PCI-S3 ViRGE-2MB-sebaz_ri-83.3
Reply 252 of 296, by sebaz_ri
PCChips M598LMR:
Intel-Pentium-66-2.0-133-PCChips-M598LMR-SiS 530-512KB-PCI-Trident 9685-2MB-sebaz_ri-90.9
Reply 253 of 296, by jwt27
Here's mine 😀
Intel-Pentium_II-100-3.5-350-MSI-MS_6119-440BX-512k-AGP-3dfx_Voodoo3_2000-16MB-jwt27-539.9
Reply 254 of 296, by jwt27
And here's the same system with a P3-450:
Intel-Pentium_III-100-4.5-450-MSI-MS_6119-440BX-512k-AGP-3dfx_Voodoo3_2000-16MB-jwt27-674.1
edit: WTF, did I just beat a 1000MHz P3 😳
Reply 255 of 296, by RogueTrip2012
🤣, you beat my PIII-S 1400MHz also with a V3. Something I'm doing wrong. Lets see. Probably something to do with fastvid.
With fastvid.bat+3dbench2.bat I get 151.0
With just 3dbench2.bat I get 539.3
Followed the instuctions to a T 😁
Anyways, Socket 370 obviously.
Intel-Pentium 3S-133-10.5-1400-ASUS-CUSL2-CB-Intel 815EP-None-AGP-Voodoo 3 3000-16MB-RogueTrip2012-539.3
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 256 of 296, by CimonVG
oldschool test result:
Intel-8088-5-1-16-clone PC XT -cpuupgradecard: Inboard 386/pc-?-0-ISA 8bit-ATI mach32-0.5 Mb Vram-cimonvg-4.3
Reply 257 of 296, by SquallStrife
IBM-6x86MX PR200-66-2.5-166-Jetway-J5TXC-Intel TX-512KB-PCI-Matrox Millennium II-4MB-SquallStrife-234.6
Reply 258 of 296, by SquallStrife
Just having a look at the OP, it seems like my 6x86 actually performs rather well for its meagre 166MHz clock speed!
Will it be updated some time? I can see a lot of scores that aren't on that score sheet.
