Reply 240 of 505, by appiah4
Cyrix200+ wrote on 2020-02-03, 08:50:
If time permits I will replace the TEA2025 tonight. I think I will socket it this time, the only spares I have are from the same dubious cheap eBay batch I ordered when I built my Snark Barker.
I put sockets for all ICs in these projects; did that with my Adlib and doing that with my SnarkBarker.. It's best to not bet on getting lucky in life. 😉
Reply 241 of 505, by Cyrix200+
appiah4 wrote on 2020-02-03, 09:10:
The TEA2025B spec sheets says to not socket it (I think to transfer heat to the PCB).
2.6 Stability A good layout is recommended in order to avoid oscillations. Generally the designer must pay attention to […]
2.6 Stability
A good layout is recommended in order to avoid oscillations. Generally the designer must pay attention to the following points:
●Short wires of components and short connections.
●No ground loops
●Bypass of supply voltage with capacitors as close as possible to the supply IC pin. The low value (polyester) capacitors must have suitable temperature and frequency characteristics.
■No sockets
The heatsink can have a smaller factor of safety compared with that of a conventional circuit. There is no device damage in the case of excessive junction temperature: PO (and therefore Ptot) and Id are simply reduced.
https://nl.mouser.com/datasheet/2/389/stmicro … 172-1204396.pdf
1982 to 2001
Reply 242 of 505, by appiah4
Cyrix200+ wrote on 2020-02-03, 09:14:
The TEA2025B spec sheets says to not socket it (I think to transfer heat to the PCB). […]
2.6 Stability
●No ground loops
■No socketsThe heatsink can have a smaller factor of safety compared with that of a conventional circuit. There is no device damage in the case of excessive junction temperature: PO (and therefore Ptot) and Id are simply reduced.
That's certainly strange.. Maybe I should add some of those leftover small heatsinks from Raspberry Pi kits to mine..
Reply 243 of 505, by Cyrix200+
appiah4 wrote on 2020-02-03, 09:23:
2.6 Stability
●No ground loops
I'm not sure cooling is the reason, but that's something I remember reading. I guess it might also help to reduce noise.
1982 to 2001
Reply 244 of 505, by appiah4
Cyrix200+ wrote on 2020-02-03, 09:30:
@root42 did you socket your amplifying IC?
Reply 245 of 505, by root42
In theory the TEA2025 should not be socketed, since the PCB acts as a heat sink. However, I also have it socketed, due to many bad TEAs out there. If in doubt, you can put a tiny heatsink on it.
YouTube and Bonus
Reply 246 of 505, by Cyrix200+
Desoldered old TEA2025, put in socket, put in new TEA2025. Still the same 🙁 Some curses followed, intense staring at the Snark Barkers design at GitHub.
And then remembering the words of a wise average man:
... the only spares I have are from the same dubious cheap eBay batch ...
Soooooo replaced the TEA2025 again and: it works fine again!
Never trust the cheapest IC's you can find on eBay . I wonder how long this one will last 😁
1982 to 2001
Reply 249 of 505, by appiah4
Are there any pin compatible alternatives to TEA2025 that sound cleaner and are more durable?
Reply 250 of 505, by root42
appiah4 wrote on 2020-02-03, 21:13:
I don't think there are pin compatible ICs to the TEA2025. We are stuck with it on the Snark Barker. But it is common and cheap enough that it should last us for a while... 😀 In 10 years we can print our own replacements...
YouTube and Bonus
Reply 251 of 505, by root42
Prototype stainless steel bracket. I will have enough of these prototypes soon for the people who ordered their PCBs with me. I will send out emails. The prototype has ONE error though: the leg which attaches to the hole below the volume wheel is misplaced by 3mm. So the bracket will hold in place ONLY by the DB15 connector, which is fine, I think. I will have an adjustment and publish the DXF for people to make their own brackets. But I CANNOT produce more brackets, most probably without considerable cost. Not sure how much demand there would be anyway...
1.12 MiB
1.44 MiB
YouTube and Bonus
Reply 254 of 505, by mongaccio
Well first of all, thanks to the fine guys at Tube Time that have retro engineered the Sound Blaster, they did a meticulous job, all those schematics, the PCB replica free to print..
Back in September/October i sent the gerber files to Jlcpcb, didn't spend too much for the minimum order of 5 cards.
Started ordering lots of different IC's from China probably including many 'fakes'. (Old chips sanded and rebranded) But oh boy they were so cheap, and i have enough to make 4 more cards.
Scrounged some components from old cards.
Decided to put sockets to every chip, to test and replace potential faulty ones.
Here it is
276.8 KiB
Well the good news is it fully works, even with all shady components imported from China. Had no issues with programming the microcontroller on the card.
Here i am testing the microphone input with a famous (at least for me) parrot.
104.31 KiB
I 3d printed the bracket using Thermalwrong files. Had to adapt it to my out of standard Jacks, very nice tho.
Bad news i didn't find the original potentiometer for cheap, i did use another (working really fine). I'll replace it in the future,or glue a new wheel on it.
Midi sound is excellent, digital audio works fine.
I did even try the SAA1099 with Monkey island and it works. Really interesting sound.
Reply 255 of 505, by Cyrix200+
root42 wrote on 2020-02-17, 14:18:
Oh, missed this message earlier. They look great!
1982 to 2001
Reply 256 of 505, by appiah4
What is the easiest way to completely bypass the potentiometer and set it to something around a fixed 70% amplification?
Reply 257 of 505, by mongaccio
appiah4 wrote on 2020-02-28, 07:30:
First of all , i'm Just an hobbyist in electronics, so take all this with a grain of salt.
Well it is more complicated than i thought, as you can see the pot is put before the amplifier, with grounding and capacitors all around.
61.28 KiB
My 2 cents of reasoning. As far as i can see here must be 10 kohm between ground and the origin of the signal .
so you need 2 different resistors for each line 4 resistors in total,x and y. Let's say x is 3.3 kohm and y is 6.7 kohm
X+y must be 10kohm, and you take the signal between these 2.
63.11 KiB
If someone with a degree in electronics can confirm this is right , that would be much appreciated
Reply 258 of 505, by Benedikt
The choice of the two resistors for each voltage divider would also have to take into account whether the volume pots are linear or logarithmic, i.e. whether the goal is 70% of the input voltage or 70% perceived volume.
Reply 259 of 505, by root42
Benedikt wrote on 2020-02-29, 08:19:
You could try both variants by using a potentiometer and tuning it to the desired volume (either linear or logarithmic). Then you can fix it with a drop of loctite. Thereby avoiding all the redesign. 😀
YouTube and Bonus
