Reply 2500 of 2532, by RetroGC
Falcosoft wrote on 2026-03-10, 14:54:You should consider loops as a continuous way of the playback of the patterns. That is it's the same as if you copied the patterns where the loop starts to the end of the song. So if the pattern where the loop start does not define its own volume level it inherits the volume settings (and of course others as well) from the previous ones. So if no effort is done to prevent differences it's more likely than not that after a loop the patterns will sound differently (volume, pan etc. differences) since the previous patterns before the looped ones differ. You have to make sure that you insert the volume, pan etc. settings to the beginning of the 1st looped pattern to make sure they have the same values as inherited from the previous patterns at 1st playback time without the loop.
I was thinking the same thing, but this bug doesn’t occur when the loop repeats—maybe right at the start, but actually right in the middle of the loop. You can already see it clearly in the waveform: it’s the central portion that’s messed up. The file was generated with OpenMPT. Problems occur with original UMX too.
