Reply 2520 of 2523, by Falcosoft
- l33t
zaphod77 wrote on Today, 04:42:i think it's because i'm on windows 11. […]
you are on windows 10, and it works.
messing with compatibility didn't help.
for my final test i'm closing down chrome completely.
didn't matter. tyrus 1,256,000,000 ver and vampire do not load, and it's definitely the 32 bit player
test version didn't change anything.
Hi,
I meant a screenshot about the ...About box where the versions can be seen.
BTW, I have just tested also the newest test version on Win 11 and it works perfectly :
Some things you can try:
1. Try to run FSMP as Administrator (although this is not needed, maybe it can show what kind of problem you have).
2. Make sure the dll is not blocked by Windows (blocked state is the default for downloaded files).
