Reply 2580 of 2588, by Falcosoft
- l33t
Roland User wrote on Yesterday, 10:15:This at all inexplicable ! You make two identicaly version , but on hash this not match )
at the same time nowhere not provide checksums as compressed in UPX so uncompressed versions , what for so do ?
And I think what not need do compression UPX if you place files on your site , because if do compress already compressed files , size of ZIP archive will bigger , also because your project aim on retro PC , UPX files with usage consumes more memory if compare this with file whitch not compressed in UPX , UPX consumes memory size UPX + uncompressed of UPX )
First of all control your tone or I will not bother with any of your stupid artificial problems... If you do not like any of my software your are not forced to use it.
Simply use something else that is packed and works the way you like.
This would make both of us happier.
