Phil's Ultimate VGA Benchmark Database Project
Reply 260 of 495, by LunarG
Just updated your spreadsheet with results using my new Intel DX4 chip. I got an overall improvement of 13.34fps, which I think is quite impressive. Intel clearly was faster than Cyrix when it came to the DX4 models.
Especially the improvement in PCPbench are impressive, a whopping 5.4fps increase. That's an increase of 39.4% ! Astonishing in my opinion.
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 262 of 495, by RacoonRider
Mau1wurf1977 wrote:
Yes you can't go wrong with Intel.
I found the IntelDX4 to be faster, clock for clock, compared to the 5x86 P75 as well.
I'll test that 😀 The 5x86 has twice as much L1 cache. Too bad I don't own any Intel DX4 chips.
Reply 263 of 495, by vetz
Already been proven by feipoa in his Ultimate 486 Benchmark. (People should start referencing this material more often)
Observing just the three DX4-100's (Intel, AMD-WT, and Cyrix), the Intel piece won by a landslide, followed by the AMD and Cyrix parts. This may be understood by the following explanation: The Intel CPU has 16 KB of write-back cache while the Cyrix part only has 8 KB of write-back cache. The AMD falls in last because it has 8 KB of write-through cache. An AMD DX4-100 with 8 KB of write-back cache does exist, but was not available for testing. There also exist 16 KB, write-back versions of the AMD DX4-100 (which were later added to the chart and are referred to as AMD DX4-100-WB) which emerged more than a year after the X5 133. The AMD DX4-100-WB-16KB was not commonly found in consumer-marketed 486 machines, however, for completeness, a 100 MHz down-clocked X5-133 was added to the charts to simulate this CPU. The AMD DX4-100-WT was the most common of the AMD DX4's at 100 MHz. The AMD DX4-100-WB now steps ahead of the Cyrix DX4-100 in ALU performance (it has 8 KB more cache than the Cyrix), however still falls considerably behind the Intel DX4-100. The Intel piece clearly had a performance edge for DX4-100 class processors.
Please note that the Cyrix 5x86 does beat the Intel DX4 clock-for-clock
Reply 264 of 495, by mr_bigmouth_502
The 5x86 always struck me as being kind of a sluggish chip for its supposed clock speed. Would a slightly overclocked DX4 100 be able to outperform one?
Then again, the one 5x86 system I had a long time ago was rather poorly set up, and when it had a 66MHz DX2, it performed nowhere near as well as my other DX2 system despite having more ram and a newer video card.
Reply 265 of 495, by vetz
According to feipoa's benchmark, no.
This is a Intel DX-120 vs a AMD 5x86 X5-133. While the DX-120 is a 0.1 point quicker in ALU performance, the X5-133 wins with better FPU, so in overall the X5-133 wins
Reply 266 of 495, by RacoonRider
Okay 😀
Reply 267 of 495, by Mau1wurf1977
I think calling it sluggish is misleading 😀 I don't want to be the reason for spreading false rumours 😊
But I found that compatibility with motherboards and BIOS are better with the IntelDX4 and that the 5x86, while being faster, isn't that much faster and doesn't make games that struggle on a IntelDX4 suddenly fluid.
Edit IntelDX4 100 IntelDX4-100 Integrated FPU 486 (Socket 1-3) 33 MHz 3x 100 MHz 70.1 20.3 40.16 10.6 Biostar 8433UUD-A VER:2
11 Edit Am5x86 133 Am5x86-133 Integrated FPU 486 (Socket 1-3) 33 MHz 4x 133MHz 79.9 20.4 46.28 12.6 Biostar 8433UUD-A VER:2
The scores are for 3dbench2, pcpbench/vgamode, Doom and quake.
My YouTube channel
Reply 268 of 495, by LunarG
My DX4 has 16KB WB L1 cache, so no, the 5x86 doesn't have twice as much cache.
I guess that cache is part of the reason for the massive performance boost.
Reply 269 of 495, by mr_bigmouth_502
Mau1wurf1977 wrote:
I think calling it sluggish is misleading :) I don't want to be the reason for spreading false rumours :blush: […]
What if you ran that DX4 at a 4x multiplier, or compared the two with a higher FSB setting?
Reply 270 of 495, by dacow
Ignore me guess Quake doesn't run without FPU 😀
Reply 271 of 495, by RacoonRider
DX4 has 2x multiplier instead of 4x.
Reply 272 of 495, by kixs
It doesn't. But 486DX do have it integrated. Look in the spreadsheet for benchmarks.
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 273 of 495, by dacow
Ahh yeah my original post about me adding a 386DX40 into the spreadsheet but I didn't realise that most of the other 386DX's (without co-pro's) had 0's in the Quake column!
Reply 274 of 495, by RacoonRider
Added a bulk of information from earlier runs, fixed validation up to row 450, now the perfectionist inside me is happy.
dacow, AMI BIOS string you posted suggests your 386DX-40 motherboard is made by Soyo. To identify your board look for a small yellow sticker, it should say something like "019R1":
http://lh5.ggpht.com/_bNUAEXCfAto/TIjdrJiEAJI … 24/PICT0060.JPG
That's the way they labeled their boards.
Or look it up in th99: http://museum.ttrk.ee/th99/
Reply 276 of 495, by dacow
I just realised that mobo has been packed back up and shipped back to Badmofo!
Reply 277 of 495, by GeorgeMan
Added two 386DX40s and a 486DX2-66 to the database! 😀
Tomorrow I will test 10-15 more combinations, ranging from 386SX-20 to Pentium III 750! 😁
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 279 of 495, by GeorgeMan
33 results uploaded!
I saw no point in trying P133-K6/300 on the 2 newer motherboards, if anyone else wants just say it. 😀
It is also pointless for me to bench more PIII/Celeron (366-933MHz) as they are pretty much too fast for these DOS benchies.
