My Very Long Bus Adventure.
Reply 260 of 272, by Chadti99
mkarcher wrote on 2023-10-16, 20:30:
Chadti99 wrote on 2023-10-16, 20:10:
mkarcher wrote on 2023-10-16, 19:36:
And indeed, the RGB524 is a 5V tolerant 3.3V chip.
That is interesting, I wonder why the VRM is needed. I can def put a meter on it.
If you still wonder why there is a VRM, I am sorry for using expert-only terms which were not clear enough. "a 5V tolerant 3.3V chip" means that this chip is a operating with 3.3V supply voltage. That's why the VRM (actually, it's not a voltage regulation module, just a voltage regulation chip) is needed. The IBM RGB524 will possibly blow up if you feed it with 5V. So why did call it 5V tolerant then, if it can not tolerate 5V supply? Because in electronics design language, this term is defined to mean "this chip can handle 5V on the data/signal lines even if it is powered by a lower voltage". The standard way of constructing chips designs input in a way that they are moderately resistant against ESD (electro-static discharge), but they can't withstand voltages above the supply voltage or below GND, because that case is treated like ESD. While small electro-static discharges have high voltage, they only have a tiny amount of power, so if the chip shorts that power out, the danger is gone. On the other hand, if you actively and continously supply voltages outside the permitted range, you might damage the chip.
"5V tolerant" means the chip is built in a special way that the ESD protection circuit is modified in a way that 5V on the data pins is not shorted to the 3.3V supply pin, so the chip works without any trouble when it receives 5V signals on some or all of its inputs (in case of the IBM DAC, all the signals it receives are 5V signals).
Got it, makes sense, appreciate that detailed explanation. Probably makes sense to check the voltage coming out of that VRM?
Reply 261 of 272, by mkarcher
Chadti99 wrote on 2023-10-16, 20:34:
If you can easily check it without shorting anything while trying to do so (best case: the mainboard is not mounted in a case, and there are no other cards near to it), testing the VRM makes sense, because it's easy. I don't think a broken 3.3V regulator is likely, though. In what way does the card "show no signs of life"? Does the computer still boot with the card installed? Does it emit the typical "no graphics card installed" POST error beep?
Reply 262 of 272, by Chadti99
mkarcher wrote on 2023-10-16, 20:43:
Exactly this, one long beep then three short. Quick pause between first two short beeps. No output to monitor.
Reply 263 of 272, by mitchkramez
Chadti99 - would you be able to dump the bios from the S3 Diamond SE VLB card and post it here or upload it to the vgamuseum? I have a card that's missing the bios. I think we can probably just use the same bios as the PCI cards use, but would be curious to compare 😀
Reply 264 of 272, by Chadti99
Is that the S3 Trio32? Not sure I still have it, let me know. I could source another though.
Reply 265 of 272, by feipoa
What did you end up doing with that VLB S3 968 card? From my experience when testing various PCI 968 cards, the cards with the TI RAMDAC output a much clearer output image compared to the IBM RAMDAC. I focused my comparison on the 1280x1024 resolution.
Reply 266 of 272, by Chadti99
I still have it, will probably build a system around it soon.
Reply 267 of 272, by Chadti99
Gotta get an update in here before year end. Found an ATI Mach64 Graphics Pro Turbo VLB! Can anyone comment on the best settings, bios and jumper, to run this board in an ASUS 486SV2GX4 with a POD100? Seeing some junk output at times in DOS or DOS Games, not in Windows though, at least not yet.
Reply 268 of 272, by pshipkov
From my notes:
DRAM SPEED = SLOWER for some tests to pass successfully with Asus VLI-486SV2GX4 2.1. It is implied that everything else is on max.
Best results in Windows 3.1 achieved with driver version 3.098.
EDIT:
More details in this post - it is more or less the complete list of VLB graphics chips tested and benchmarked on Asus VLI and PVI motherboards.
retro bits and bytes | DOS media library
Reply 269 of 272, by Chadti99
Thanks pshipkov! I think the DRAM speed setting has corrected the issue. My system hangs at the “slower” setting but I’m able to boot at “slowest” which is unfortunate for performance. This card may not be suited for this motherboard so I’ll def try it in a couple others.
Who’d of thought dram speed would cause issues with your video card, my ARK1000 runs fine at the “Fastest” dram setting. The VL bus is so wierd.
Here’s an example of what you’ll see, Doom looks great for a minute and then:
Reply 270 of 272, by pshipkov
ATI VLB cards are decent overall, but they may struggle in highly optimized configurations.
The Asus VLI motherboard is an excellent platform for VLB expansion cards.
Nearly all VLB adapters I’ve tested on this board function smoothly, even with the system fully maxed out.
However, there are a few exceptions - one example being that Mach64 card.
Your problem has its positive side too - auto invisibility mode in combination with parental control for limited play time.
Reply 271 of 272, by Disruptor
Well, my ATI Graphics Ultra Pro VLB (2 MB VRAM, ATI Mach32) does not like 40 MHz FSB too.
