3DBENCH CPU Benchmark Database
Reply 280 of 296, by kixs
Now it does explain 😉 Your results are missing from the spreadsheet - so with the ones in it, it looked like Ali5 is slow.
What Quake version did you use? With v1.06 I get 53.5 fps (233MHz and Voodoo 3 3000 PCI - didn't test it with TNT2 M64).
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 282 of 296, by kixs
I think 1.06 is the latest shareware.
I guess 3Dbench is more of a gaming benchmark then just a CPU one. In the past I never tested it with different video cards and it can make quite a difference.
Reply 283 of 296, by leileilol
1.06 is the latest shareware. However note that there's a Quake benchmark database out there based on the old 0.91 shareware that also has "mysteriously slower" 1.01 benchmarks. The only visual change 1.01 had (1.00 really) is 64 colormap levels for overbright.
1.07/1.08 ditched the brown menu background and redone the sound effect spatialization.
long live PCem
Reply 285 of 296, by LunarG
Looks like this spreadsheet needs a bit of a cleanup now. Needs some clearer section dividers, and redone numbering. Can't really tell where 486 ends and Pentium begins now.
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 286 of 296, by Mau1wurf1977
Hmm someone has totally messed it up 🙁
I've restored it to the point just before someone messed with it.
My YouTube channel
Reply 287 of 296, by kixs
I've done some testing with P-233MMX on Gigabyte GA-5AX oc'ed to 250, 300, 315 and 330MHz. 330 is only 3dbench stable, Quake crashes almost immediately after starting demo1. Results for Pentium-MMX and K6-3 are added to the spreadsheet.
Reply 288 of 296, by anthony
Hello i'm new here
My results
Intel-Pentium4-2660-20-133-Nexcom nx716vl2g-intel 845gl-512kB-pci-Voodoo 5500-64MB-anthony-954
Same as above, but l1&l2 disabled 24.2 fps
And same as above but cpu 20x100 19 fps
Reply 289 of 296, by YangMimpi
Hi,
Pentium-120-60-2-120Mhz-FIC-PT2003-i430FX-256KB-PCI-Mirage-1MB-yangmimpi-111
Reply 290 of 296, by kixs
Adding one 286-12MHz to the list... but there is no 286 section 😉
Siemens PCD-2, 80286, 12MHz, 4MB RAM, 250MB HDD, ISA CL-5422 1MB
3DBench 1.0: 3.9
Reply 292 of 296, by kixs
Adding another 286
- 286-16MHz, 1MB, Trident 8900D 1MB
3DBench 1.0: 5.3
- 286-16MHz, 1MB, Tseng ET4000 1MB
3DBench 1.0: 5.5
Reply 293 of 296, by kixs
I searched but nothing concrete popped up... Is there a list of the best/fastest DOS graphic cards? I just tested some PCI ones on P-I 133MHz and the results can differ up to 25% from Trident to Matrox, Tseng and TNT2. But doesn't have to be PCI only... AGP/PCIe would also be interesting - some definite list of the best graphic cards for DOS.
Reply 294 of 296, by pewpewpew
Have added to the spreadsheet:
Intel-486DX-33-1-33-Asus-ISA-486-SIS 401/402-258kB-ISA-Trident TVGA 8900C-1MB-pewpewpew-17.2
Now that I've inserted a row, how do I adjust the number sequence of Column A?
Reply 295 of 296, by PhilsComputerLab
Just leave it, every now and then I so a sort of the entire spread sheet 😀
YouTube, Facebook, Website
Reply 296 of 296, by pewpewpew
Thanks
