Phil's Ultimate VGA Benchmark Database Project
Reply 280 of 495, by kithylin
GeorgeMan wrote:
33 results uploaded!
I saw no point in trying P133-K6/300 on the 2 newer motherboards, if anyone else wants just say it. 😀
It is also pointless for me to bench more PIII/Celeron (366-933MHz) as they are pretty much too fast for these DOS benchies.
There's never anything "too fast" for this stuff. I put my Core2Duo + HD4890 in there near the top end of the results at one point.
Reply 281 of 495, by GeorgeMan
Also added some s370 results. Now I only have a 486 100-120MHz VLB left and a 386SX.
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 282 of 495, by RacoonRider
There's a whole lot of results, mainly thanks to GeorgeMan! Phil, could you please sort them?
Reply 284 of 495, by GeorgeMan
Please stickify this! Very useful 😀
Reply 285 of 495, by Agent of the BSoD
Entered my info from my Dell Dimension 4100. Looks like I'm on the low end of fps for Doom and Quake. I blame the Nvidia GPU BIOS on this card. (GeForce FX 5500)
I also find it weird that I'm the only person with a Pentium III running at 866MHz. Stock setting for it and I can't change it if I wanted to. BIOS won't let me touch much.
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 286 of 495, by raymangold
I can bench some of my PS/2s if it would help (the PS/2E or model 33 has a 486SLC @ 50 Mhz which is quite a unique processor, and the PS/2 95 has a pentium 60 with insane cache running on synchrostream). So both of those processors will perform unusually faster than their 'regular' counterparts.
Normally they would use XGA, but I have a VGA 'MCA' card coming for the 95, and I can always throw an ISA VGA card in the model 33. Unless XGA would be preferred to be used for the testing for a curiosity factor...
Let me know,
Basic info on the PS/2E: http://www.walshcomptech.com/ps2/mod33.htm
Quick overview of Synchrostream: http://www.walshcomptech.com/ohlandl/complexes/complex.html
Silver/blue chip to the right of the purple ceramic intel cache controller is what performs synchrostream operations:
Cache chips are the five chips above both the heatsinked P60 and cache controller (and there are five more underneath for a total of 256 KB: for a strange amount of approximately 25 KB per chip).
Reply 287 of 495, by RacoonRider
raymangold wrote:
I can bench some of my PS/2s if it would help (the PS/2E or model 33 has a 486SLC @ 50 Mhz which is quite a unique processor, an […]
Let me know,
Strange indeed! As Phil stated earlier, new entries are always welcome!
Reply 288 of 495, by raymangold
Okay what I'll do is test the model 95 with an MCA VGA card, and then I'll leave the model 33 with its XGA (which is VGA compatible), just for the sake of bizarreness as there aren't any XGA entries yet. One thing I did forget to mention, the model 33 is completely fanless and uses a passively cooled PSU! A very nice touch if you want a mini pizza box pseudo-486 that doesn't generate any noise.
Reply 289 of 495, by Lukeno94
I'm going to bench a couple of systems myself - oddly, when using your menu system, the benching doesn't work with Doom on my Vaio PCG-FX601, but it works fine when I run the batch file directly from the Doom subdirectory.
EDIT: Vaio and my HP Vectra VLi8 added.
Reply 290 of 495, by GeorgeMan
Added 28 more results (reaching a total of 70 results), mainly from my slot1 sets, including many 440BX results! 😁 😁
I have one more i440BX mobo to test and then I'm finished.
Reply 292 of 495, by feipoa
mau1wurf1977, could you let me know what settings you are using for the Quake timedemo?
When I use your Quake 1.06 benchmark, I get 12.4 fps. When I use my Quake 1.06, I get 14.4 fps (timedemo demo1).
Reply 293 of 495, by Mau1wurf1977
Default settings. Didn't change a thing.
My YouTube channel
Reply 294 of 495, by feipoa
This phenomena could lead some people to think their systems are faster or slower than they really are. I wonder if it is just my system which displays this effect. Can anyone else with a 486 compare their stand-alone Quake SW 1.06 results with the Quake results in Phil's VGA package? A 15% discrepency is very curious.
Reply 295 of 495, by smeezekitty
Errr. How do I run timedemo on quake?
Reply 296 of 495, by feipoa
I beleive Quake requires you to have DOS 5.0 or above installed, or Windows 9x. I do not think you can run Quake from a boot disk even if you have the required files already on your HDD.
1) Install quake from the installer file by running install.bat.
2) run quake from DOS by typing: Quake
3) Once in quake, start a new game
4) Once the game starts, type: `
5) This will bring up the quake command console.
6) Now type: timedemo demo1
7) And immediately type: `
😎 This will close the command console and run the quake timedemo without the console taking up half the screen.
9) When the timedemo is finished, the command console will show you the frame rate.
But you need to use Quake files not part of Phil's VGA package. Even if I run Phil's Quake files independent of the batch bench file, it still indicates the decreased frame rate. I am not sure why. I thought all the 1.06 shareware versions were the same.
EDIT: The checksums of the 4 files in this zip compilation are the same as the ones I used. http://www.moddb.com/games/quake/downloads/qu … -shareware-106/
Reply 297 of 495, by smeezekitty
Ok there is something weird going on.
Running the original quake files (made from a copy of someone elses disks)
I am seeing much _LOWER_ performance (8.9 FPS)
And with Phil's bench I am seeing 11.0 FPS!
-edit-
I will try the linked version
The version you linked is also 8.9FPS
Reply 298 of 495, by feipoa
The opposite effect - very strange indeed. Are you running the benchmarks from within DOS or within Windows' DOS prompt?
Is it possible that you have sound enabled? Try removing the sound card or disabling sound in Quake (there is some command for this, but I don't recall right now).
Reply 299 of 495, by vetz
If I remember correctly Phil's benchmark run at fullscreen without UI, while default settings have the UI enabled. This explains the 15% performance difference.
According to Phil in an earlier post here on Vogons were I pointed this out it was set to fullscreen to be more heavy on faster machines (same applies to Doom).
