RReady (Rendition Verite wrapper) Test Build (Alpha 1)
Reply 2860 of 2885, by sharangad
Toshinden (CGL) for 3DBPCI tries to access these memory addresses before crashing:
0xA0F00012
0xC0F00014.
The staring digits suggest to me that page A0F00 is remapped VGA RAM and C0F00 is the remaped video BIOS (Segments A000 and C000).
In Windows '98 these addresses aren't directly used resources for the 3DBPCI.
https://www.youtube.com/@sharangadayananda
Reply 2861 of 2885, by sharangad
@robertmo3, after my changes I get this:
[code]$ make --jobs=16
/home/sharanga/qemu-10.0.0-rc4/build/pyvenv/bin/meson introspect --buildoptions /home/sharanga/qemu-10.0.0-rc4/meson.build | C:/msys64/home/sharanga/qemu-10.0.0-rc4/build/pyvenv/bin/python3.exe -B \
scripts/meson-buildoptions.py > /home/sharanga/qemu-10.0.0-rc4/scripts/meson-buildoptions.sh.tmp && mv /home/sharanga/qemu-10.0.0-rc4/scripts/meson-buildoptions.sh.tmp /home/sharanga/qemu-10.0.0-rc4/scripts/meson-buildoptions.sh
Failure in scripts/meson-buildoptions.py parsing stdin as json
../meson.build:91:12: ERROR: Unknown compiler(s): [['rustc']]
The following exception(s) were encountered:
Running `rustc --version` gave "[WinError 2] The system cannot find the file specified"
make: *** [Makefile:132: /home/sharanga/qemu-10.0.0-rc4/scripts/meson-buildoptions.sh] Error 1
[/code]
Aargh! It was caused by a custom build option ('renditionV1000pci'). It's not set up correctly.
Reply 2862 of 2885, by robertmo3
pacman -S --needed mingw-w64-ucrt-x86_64-rust
Reply 2864 of 2885, by sharangad
@robertmo3, do you know where this has to be defined CONFIG_VGA_CIRRUS for the cirrus vga driver files to be compiled?
I've got my own pre-processor define CONFIG_VGA_RENDITION defined and I've set it up in:
config-poison.h
and
i386-softmmu-config-devices.mak
but it just ignores it.
Reply 2865 of 2885, by robertmo3
how about just replace cirrus with your source under the cirrus name.
this way it may easier
Reply 2867 of 2885, by Gona
sharangad wrote on 2025-05-20, 05:08:
Quick test for someone with a 3D Blaster VLB: […]
https://nirvtek.com/downloads/SMODEVLB.20250520.001.7z
MD5: 954dfb5f90f7a34ceef87dbec65791db
(Corrects bug)
https://nirvtek.com/downloads/SMODEVLB.20250522.001.7z
MD5: 4fa8357c9ddd9b4afa8e06adb075f08d
Run SMODEVLB > vlb.txt.
Attach the VLB file or its contents or share it somehow.
It wrote this in the vlb.txt
Error in EXE file
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 2868 of 2885, by sharangad
Gona wrote on Yesterday, 17:38:
It wrote this in the vlb.txt […]
(Corrects bug)
Error in EXE file
Which OS are you running under and what's your 2D card? Also can you check the MD5 checksum just to make sure my website isn't messing up. I did download it again from nirvtek.com/downloads to verify and it seems ok.
For instance under W98 with a 3DBPCI (which is also being studied at the moment) I get the attched file. What I'm really interested in is the first 4 int calls.
Reply 2869 of 2885, by sharangad
Does anyone know where I can get the VMWare disk mount utility? QEMU uses vmdk files.
The Broadcom/VMWare doesn't show up in a google search. A bunch of dodgy sites do though.
[EDIT] VMWare VMs can't access it, I think I need to reboot for that.
Reply 2870 of 2885, by sharangad
@robertmo, do you know how to build the seabios PC BIOS?
Nm, there's a makefile in there.
[EDIT]
In file included from scripts/kconfig/zconf.tab.c:2534:
C:/msys64/home/sharanga/qemu-10.0.0-rc4/roms/seabios/scripts/kconfig/confdata.c: In function 'conf_split_config':
C:/msys64/home/sharanga/qemu-10.0.0-rc4/roms/seabios/scripts/kconfig/confdata.c:929:56: error: too many arguments to function 'mkdir'
929 | if (stat(path, &sb) && mkdir(path, 0755)) {
In file included from C:/msys64/ucrt64/include/unistd.h:10,
from scripts/kconfig/zconf.lex.c_shipped:777,
from scripts/kconfig/zconf.tab.c:2532:
C:/msys64/ucrt64/include/io.h:297:15: note: declared here
297 | int __cdecl mkdir (const char *) __MINGW_ATTRIB_DEPRECATED_MSVC2005;
In file included from scripts/kconfig/zconf.tab.c:2536:
C:/msys64/home/sharanga/qemu-10.0.0-rc4/roms/seabios/scripts/kconfig/symbol.c: At top level:
C:/msys64/home/sharanga/qemu-10.0.0-rc4/roms/seabios/scripts/kconfig/symbol.c:10:10: fatal error: sys/utsname.h: No such file or directory
10 | #include <sys/utsname.h>
Reply 2871 of 2885, by robertmo3
you can open hdd images in daemon tools lite
you can use the 2gb image from my qemu build
Reply 2872 of 2885, by robertmo3
Supported HDD Image Formats:
RAW: A simple, byte-by-byte storage format that is easily exported to other emulators.
QCOW2: QEMU's primary image format offering features like snapshots, compression, encryption, and smaller images on filesystems that don't support sparse files.
VHD/VHDX: Hyper-V formats for interoperability with Microsoft's hypervisor.
VDI: VirtualBox format for compatibility with VirtualBox.
VMDK: VMware image format for interoperability.
Bochs: A format for growing type images.
Cloop: Linux compressed loop images.
dmg: Apple disk images.
Parallels: Parallels disk image format.
Reply 2873 of 2885, by robertmo3
DAEMON Tools Lite 10 allows you to mount all known types of disc image files
Reply 2874 of 2885, by robertmo3
just in case
all the needed bioses are here: qemu-10.0.0-rc4\pc-bios\
SeaBIOS (bios.bin)
Reply 2875 of 2885, by sharangad
robertmo3 wrote on Today, 08:12:
just in case
SeaBIOS (bios.bin)
I need to recompile the BIOS with some of my changes. It does't compile and its not because of my changes.
Reply 2876 of 2885, by sharangad
robertmo3 wrote on Today, 07:42:
I need to copy some new stuff over to your 2 gb image.
Reply 2877 of 2885, by robertmo3
just mount that hdd image in daemon tools lite
Reply 2879 of 2885, by sharangad
robertmo3 wrote on Today, 09:11:
I'll try that.
Does anyone know what this error means:
unable to begin graphics memory system: MX1 error 19
in the context of Nascar 1 with the Matrox Millennium 2 MB (IS-MGA-2064W, 2 MB).
