Reply 30400 of 30404, by sunkindly
- Member
PC@LIVE wrote on Yesterday, 18:19:Looking at the images, I can tell you that the CPU is blocked, you can only use two multi, 2.5X and 3X, the 2.5X one definitely […]
sunkindly wrote on Yesterday, 17:51:Photos below, but in doing some more testing...it seems like the jumpers don't do anything at all to change it from 2.5x. […]
PC@LIVE wrote on Yesterday, 09:51:Hello, if I understand correctly you have an S.7, but the CPU goes to a maximum of 166 MHz, so first of all 😨 I would check what is written on the CPU, for example Pentium XXX MMX SXXXX (the X's indicate what you will find written, they are important), already from there it would be possible to better understand the problem.
Then if maybe 🤔 you can take some photos, and attach them here, possibly motherboard and CPU, or if you can jumper zone (multiX), it would be possible to compare your settings with those of the manual (if you have one), but in any case even in the absence of the manual, it is possible to do some tests, to see to set the jumpers on 3X, currently it should be on 2.5X, if instead it is on 3X and does not go to 200, speaking of Intel CPU, you could have a 166 MHz CPU with multiplier blocked to go up.
If so, the only way to increase the frequency is to raise the FSB, if that board allows it, you can switch to 75 MHz, you get 188 MHz that the BIOS could interpret as 180 or 200 MHz, maybe that's how they showed you the 200 MHz.Photos below, but in doing some more testing...it seems like the jumpers don't do anything at all to change it from 2.5x.
So JP16 and JP17 seem to set the fsb, but for JP19, JP20, and JP22 no matter what I set them to...it didn't change from 2.5x at 166MHz. Even setting it to something "normal" like 133MHz at 2x, nothing changed. The only thing that seemed to affect change was changing the FSB through JP16-17. But unfortunately, it doesn't support more than 66MHz.
The silkscreen doesn't mention anything about P55C or a 3x multiplier, but it has the jumpers to set dual voltage (which I did) and since it's POSTing I'm assuming that's actually working. So I'm not sure...
Looking at the images, I can tell you that the CPU is blocked, you can only use two multi, 2.5X and 3X, the 2.5X one definitely works, while the 3X one doesn't seem to.
But it could be something else, first, you can use a software to see the actual frequency, it could for example be a dated BIOS that makes you see only 166 MHz, when in reality it is 200.
One that you can easily find is CHKCPU, it works with DOS, or if you have Windows 95-98 you can try CPU-Z, both can show the actual frequency.
For the rest it's a motherboard that's fine, if you don't need to update it, that is, you want to use it as it is, and according to what it says, the jumpers are set up in the right way.
Perhaps the BIOS version is the factory version, and it is not accurate in reading the frequency (?).
I was hoping that might be the case but sadly CHKCPU and Speedsys both report 166ish...maybe I have some kind of early revision or is it the CPU?
BIOS is updated to the latest I found.
Either way I have a QDI Titanium 1E on the way so we'll what happens with that one 😮💨
SUN85-87: NEC PC-8801mkIIMR
SUN88-92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN94-96: BEK-P407 | Cyrix 5x86 120MHz | Tseng Labs ET6000 | SB 16
SUN98-01: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
