Recently i peep into a preinstalled version, to get more info i need to install it.
But X-Com UFO defense should support FM, MT, GM.
Music Libraries and drivers are present for each of them.
It even supports the GUS natively.
Perhaps i can tell you more in a month or so, this is somehow interesting.
Especially because of the dedicated MT32 midi, i like that.
I can imagine well that will offer the creepiest and most alianized sound if it uses custom instruments (which seems to be the case but i can't tell it yet exactly).
Unfortunately even if i extract the midi from their ".bin" packages they are still compressed or in a to me unknown headerless format (raw midi it isn't but at least MIDIPLEX shows that it is a midi).
Installing the game will give me more answers.
Probably it's HMI MIDI.
Which can produce wrong results on recent machines even in DOSBox as i experienced because generally you only pipe the MIDI stream to the MIDI mapper and i noticed on my Win10 that the HMI of FFE are interpreted wrong now, the notes of certain tracks won't end as they should, converted to a GMIDI the play back well - depending on the player, Megamid produces the same error but played back with WinAmp or PX and the miles drivers they are fine.
If that is the case i appreciate your problem because it can bring me closer to the solution of my problem with FFE.
But yes overall the SBFM isn't that bad no?
Sometimes i really like the artificial sound of the FM.
But well i can be even fascinated of Tandy sound 😀
