Reply 320 of 348, by Stesch
- Newbie
The only slower crystal I have is a 12,28 MHz one. I will try it later today and report back if the floppy drive still works 😀
While running dos, the time runs too slow (around 10%). In case of the benchmark results, all benchmarks that use the timer will be off for sure. I'll repeat the benchmarks later (I'm not sure if I'll get around to it today) with the stock 14,318 crystal @120Mhz so we have some values to compare.
Speedsys also fails to display the correct CPU speed but displays 150MHz instead. Do you know another tool to measure the CPU speed perhaps? CHKCPU also displays 150, so I guess it uses the same approach (using the timer) as speedsys...
crayon eater (but only the tasty ones)
