Reply 320 of 331, by ruthan
pappyN4 wrote on 2025-05-12, 23:29:
Was hoping to bring it down to a P200 era for some speed sensitive games. But I think i overshot a bit with disabling the cache.
100x slower is not exactly great scaling try to fiddle with slowdown programs like SlowDos, they have their issues too, but they mostly work and there is multiple of them, so i one dont, you still have some options..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 321 of 331, by vico
I have a SL2YM Slot-1 Pentium 2 processor in my M748MR mobo, which I can configure from the BIOS as 4x66MHz=266MHz and 4x100MHz=400MHz. Can I switch between the two modes with SetMul or some alternative tool?
Reply 322 of 331, by gerwin
vico wrote on 2025-07-14, 02:15:
There are some tools like SoftFSB https://www.majorgeeks.com/files/details/softfsb.html
But it needs to support the PLL chip on your motherboard. And I don't see M748MR mentioned in the file SoftFSB.dat. A SiS 620 based PC-Chips motherboard is rather uncommon...
Reply 323 of 331, by vico
gerwin wrote on 2025-07-14, 16:20:
It's sad to hear but thanks for responding.
Reply 324 of 331, by ux-3
I am adding to this thread because I have high hopes to get a competent answer here. 😉
I am unsure if buying an AMD K6-3+ is going to be an improvement for my case of use, which is mostly "slowing down" for DOS.
My situation:
I have an S7 ATX board with Intel TX chipset and a SS7 µATX with SIS 530 chipset. I can already use P233mmx or AMD K6 500.
The SS7 states support for K6-3 and has voltage settings 1.8V and 2.1V (and higher). The S7 has voltage settings of 2.0V and up.
While I do have a Voodoo1 in the TX machine, both machines are geared towards DOS and early windows gaming. I therefore use them with the P233mmx, which Setmul can manipulate well. I can switch the P233 to 133 with an external switch and have the option to turn off external cache in bios.
Here is my question:
If I replace the P233mmx with a K6-3+ or a K6-2+, will I gain any slowdown options over the P233mmx?
Will I lose any slowdown options I had with the P233mmx?
Or asked differently: Which one is better for slowing down?
I realize that I will gain options to increase the speed with a K6-3+, but those would only be of value if the slowdown ability of the P233mmx isn't lost or diminished much. (I have a K6-2 500 already)
Retro PC warning: The things you own end up owning you.
Reply 325 of 331, by Kruton 9000
ux-3 wrote on 2025-10-18, 15:04:
I am adding to this thread because I have high hopes to get a competent answer here. ;-) I am unsure if buying an AMD K6-3+ is g […]
My situation:
The K6-3+ is more convenient to slow down, as all manipulations can be performed on the fly using software.
Pentium MMX has more options for slowing down, and slows down in smoother steps to slower speeds. However, at a minimum, to change the multiplier, you'll have to power down the computer and adjust a jumper/switch. And this is in addition to manually changing the bus speed in the same way.
For most people, the K6-3+'s capabilities in slowing down is sufficient, and the convenience and increased performance are preferable. But if you already have a processor that slows down even better, and you're satisfied with the performance, then you may not need a different one. So the choice is yours.
I'd advise you to first understand your real goals, rather than speculating about running something processor-sensitive. Many people spend years building expensive, super-universal all-in-one systems and only use a fraction of their capabilities. However, for many on this forum, assembling the system is an even more interesting hobby than using it.
Reply 326 of 331, by ux-3
Kruton 9000 wrote on 2025-10-18, 21:01:
Not sure if new ways have been found, but would I not have to do that anyway, when I want to disable the external cache?
Reply 327 of 331, by Kruton 9000
ux-3 wrote on 2025-10-18, 21:17:
For the K6-2+/K6-3+, the external cache has a minimal impact on performance, as the processor itself already has a software-controlled L2 cache. This means you can enable and disable the L1 and L2 caches separately, using SetMul only; even BIOS options are unnecessary. In this case, the cache on the motherboard can be left alone without major losses.
On the Pentium MMX, you can manage the L1 cache more flexibly, but the external cache at best will be controlled through BIOS settings. And impact on PMMX's performance is too significant to ignore.
Reply 328 of 331, by eliot_new
gerwin wrote on 2014-03-10, 14:46:
I have SetMul 1.24 but it seems to refuse to work with AMD K6 - 3 / 400 (non plus), why?
Take a look at this picture, I setup in autoexec.bat K6clk M:2 along with below it SETMUL L1D L2D but it writes an error: "CPU detect: unsupported AMD CPU detected (5.9.1) 400 Mhz. Only L1 Disabling Enabling is supported L1D / L1E
DOS:K6-3/400,192MB,P5A,Rendition v2200 AGP,Trio64 PCI,3dfx V1,AWE64,ESS1938,PicoGUS,32GB
w98SE:P3/450,768MB,QDI440BX,V3AGP,AWE64,PicoGUS,80GB
wXP:P3/1G,512MB,CUSL2-C,MSIFX5600,Audigy1,80GB
Reply 329 of 331, by gerwin
eliot_new wrote on 2026-01-20, 20:46:
Sorry, but the K6-III (non plus) does not have the required PowerNow! feature. Only the K6-2+/III+ have this.
As listed here.
https://en.wikipedia.org/wiki/AMD_K6-III
Reply 330 of 331, by eliot_new
gerwin wrote on 2026-01-20, 21:31:
Sorry, but the K6-III (non plus) does not have the required PowerNow! feature. Only the K6-2+/III+ have this. As listed here. […]
As listed here.
Thank you!
I have found out, that there are some other software tools to slow down my K6-3 / 400, I will try it out and report:
CpuSpd - A Hardware Based CPU Speed Control Utility for DOS/Win9X Retro Gaming
EDIT: CPUSPD is incredly good.
I have 5 speed profiles:
386.bat => cpuspd c1d c2d t3 ebd edd
486.bat => cpuspd c1e c2d t4 ebd edd
586.bat => cpuspd c1e c2d t5 ebd edd
P100.bat => cpuspd c1e c2d t6 ebd edd
P233.bat => cpuspd c1e c2e t7 ebd edd
With these profiles I can play all speed sensitive games:
=> e.g. Turrican 2, Ultima 6, Dune2, Jazz Jack Rabbit, OMF 2097, Epic Pinball, Monkey Island 1, except Prince of Persia 1. It freezes after starting 1st level.
I also tried a 286.bat, but it doesn't work on my K6-3: cpuspd c1d c2d t2 ebd edd: I will have to play Prince of Persia 1 in a DOS Box, but this is ok.
Reply 331 of 331, by gerwin
eliot_new wrote on 2026-01-21, 17:58:
I suppose CPUSPD is SetMul features (Though they hardy apply to a non-plus K6) combined with Throttle.exe.
http://www.oldskool.org/pc/throttle/DOS
Honestly, I am kinda pretending CPUSPD does not exist.
