Reply 340 of 434, by Grzyb
DivByZero wrote on 2025-06-08, 12:14:
With the speed good enough now, it makes me wonder how hard it'd be to hack MSCDEX.EXE to read from a CD image on the mounted drive
No need to hack MSCDEX - just use SHSUCDHD+SHSUCDX.
Make sure you use the latest versions:
SHSUCDHD 3.01 (17 May, 2005)
SHSUCDX 3.09 (2 September, 2022)
I had some issues with some earlier stuff, but the above were working fine.
so we could have swappable CD images from network storage
Depends what you mean as "swappable".
I'm afraid there's no way to change the images while playing a game - so no multi-CD games.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 341 of 434, by maxtherabbit
does it allow you to load multiple instances of the driver? I know the tex murphy games for example would let you pick a different drive letter for each game disc
Reply 342 of 434, by zuldan
This may sound odd, but until I read your post, I hadn't thought of running large late DOS games directly from the drive. I've mainly used it to shunt files on and off the machine. With the speed good enough now, it makes me wonder how hard it'd be to hack MSCDEX.EXE to read from a CD image on the mounted drive, so we could have swappable CD images from network storage. Of course, analog CD audio wouldn't work so it probably wouldn't be much use in practice.
It’s fantastic having all your game ISO’s on the network (I use SHSUCDHD + SHSUCDX). Huge space saving with DOS machines being so limited in local disk storage. Even though I have the original CDs, the period correct CDROMs are really miss and hit these days. Sometimes CDs can be read sometimes they can’t. Depends how the CDROM drive is feeling on the day 😉
The ultimate though would be to use NETDRIVE + play IPX network games at the same time (which appears to be impossible to have TCP and IPX running at the moment). I haven’t had a chance to try this yet Re: mTCP NetDrive: network attached storage for DOS 2.0 or better
Reply 343 of 434, by mbbrutman
maxtherabbit wrote on 2025-06-08, 13:24:
Up to 24 drive letters are available all from the same driver. The memory requirements grow slightly with each allocated drive letter - less than 100 bytes.
On a normal system, that's 23 or less drive letters that are actually available. To get all 24 drive letters you would have to boot from a floppy drive and not have a hard drive.
Reply 344 of 434, by doshea
I have a vague memory that I read that some NetWare redirectors would let you get a few extra drive mappings in by having some non-letter "drive letters", e.g. perhaps "::"? I can imagine lots of software wouldn't like that much though!
Reply 345 of 434, by Grzyb
NetDrive server console shows something like:
2025-06-11 11:07:30 New Session: 48027, Addr: 192.168.0.102:8272, Protocol: 2, Image: test2g.dsk (RO) Journal type: No Journal
What's that "Protocol: 2"? NetDrive protocol version?
UDP would be 17, 2 suggests IGMP - but it doesn't make sense here.
Reply 346 of 434, by mbbrutman
It's the NetDrive server protocol version number.
There are two different version numbers:
  • One between the device driver and the command line utility program. Those must match exactly.
  • One between the DOS side (device driver/command line utility program) and server. The server should support the most recent versions of the DOS code.
Reply 347 of 434, by mbbrutman
Just for giggles I tried NetDrive under Windows 98. It worked. Kind of ..
  • I told the BIOS of the machine that IRQ 10 was reserved for an ISA card.
  • I disabled (but not deleted) the NE2000 card through the device manager.
  • I added Netdrive to CONFIG.SYS.
  • I loaded the NE2000 packet driver and connected a drive letter to a remote machine in AUTOEXEC.BAT.
That worked, and I was able to browse the network drive, run programs from it, etc. It had side effects though:
  • Windows complained about the DOS device driver and told me performance would be degraded.
  • Drivers for my IDE adapter did not load, so Windows was using whatever BIOS support was available.
  • I lost the CD-ROM device and drive letter as a result of the IDE drivers not loading.
Windows was not happy about the DOS device driver.
Does anybody want to write a Vxd? : - )
Reply 348 of 434, by Grzyb
I tried it with 98SE with BootGUI=0, with a PCI NIC...
Running "WIN" normally caused instant crash - pretty much expected, two drivers trying to control one device is never a good idea.
After turning off the NIC in Windows, I was able to run "WIN" after "NETDRIVE CONNECT...", but any attempts to access the remote drive failed.
I only got it working correctly in Safe Mode - "WIN /D:M".
Well, mostly correctly - I've set the disk image as RO ("chmod 444"), but Windows always tries to mark its territory by writing something wherever it can - so I kept getting occasional "Write Error" messages.
Reply 349 of 434, by doshea
mbbrutman wrote on 2025-06-19, 00:43:
I suppose it should be possible to address this by installing DOS CD-ROM drivers too?
Are the complains about performance annoying, e.g. they pop up on every boot? If so, I'm tempted to see if I can find any advice in old TechNet CDs about registry changes to make the complaints go away.
Nice to hear it works though, I always thought this sort of thing should be possible somehow.
Reply 350 of 434, by mbbrutman
I didn't think to bother with the DOS drivers for the CD-ROM, as that would probably lead to other problems.
I suspect Windows got mad because it saw a block mode device driver, so it thought that all bets were off and just went into "dumb" mode. Or maybe it's a problem with that specific IDE driver. Which is funny because it knows which drive letters the device drivers are assigned too. (Or perhaps it was a different conflict ... who knows ...)
Reply 351 of 434, by vetz
mbrrutman:
I've been using NetDrive quite extensively as a storage solution for my Olivetti M28 as it only has a 20mb harddrive. I do see some programs which crashes when run from a netdrive drive letter, like Windows 3.0 and Prince of Persia. Windows 3.0 I wanted to test just for giggles, and I was not too surprised it didn't start correctly.
Both btw load fine when done from the harddrive on C:.
Prince of Persia gives a "System error" and quits to DOS and then nothing on D: (the netdrive drive letter) is accessible. It looks like the network connection doesn't work any longer (/DIR just gives error).
Any suggestions on what might be happening?
Reply 352 of 434, by zuldan
vetz wrote on 2025-06-23, 11:23:
mbrrutman: […]
mbrrutman:
Try the read-ahead version Re: mTCP NetDrive: network attached storage for DOS 2.0 or better
Reply 353 of 434, by mbbrutman
mbrrutman: […]
mbrrutman:
Can you run "netdrive status d:" and report the number of retry errors? Do the retry errors consistently increase as you are trying the DIR command?
If you explicitly disconnect the drive can you ping the NetDrive server? (If you can then this tells me that the packet driver and network card are still functional.)
I suspect that your network is dropping a UDP packet on occasion, and that is fine - NetDrive will retry. But Windows or a game are probably taking over the DOS critical error handler and hiding it from you, so if you lose the same packet three times in a row the device driver can't ask you "Abort, Retry, Ignore" and things go out of sync. So seeing the retry count go up will confirm that.
You can also try setting this environment variable first before you connect to drive D: "set NETDRIVE_RETRIES=10" . That will make it more aggressive about retrying before giving up and reporting an error.
"Set NETDRIVE_TIMEOUT=1" can also be tried - it will make the device driver time out and retry more quickly; if the problem is related to things taking too long that might help.
Mike
Reply 354 of 434, by Grzyb
mbbrutman wrote on 2025-04-29, 01:17:
Test code that has read-ahead caching is available. If you are using NetDrive and are slightly curious, please give it a shot and let me know how it works for you.
I've just tried it - it allows 286 @ 6 MHz to play CD-quality WAV files from network storage:
Minimum PC to play CD-quality PCM sound
Reply 355 of 434, by Grzyb
BTW, I think that ND_CACHE.EXE functionality should be moved into NETDRIVE.EXE/ND.EXE, and benchmarking should be automatic when connecting.
It seems necessary to keep two versions of the driver (6,144 vs. 10,672 Bytes of memory used), eg. NDSMALL.SYS and NDFAST.SYS.
When connecting, the .EXE should detect which of the drivers is loaded:
  • if NDSMALL.SYS - no benchmarking, of course
  • if NDFAST.SYS
    • if no cache size parameter is given - display something like "Finding the optimal cache size, add the parameter to skip this...", and perform the benchmark
    • if cache size parameter is given - no benchmarking, of course
Reply 356 of 434, by mbbrutman
I considered that but decided not to do that because I want to keep the size of ND.EXE as small as possible, especially since this is test code and it might not stick. Also, once you know roughly how your system and network perform you will probably not run the benchmark again.
The longer term solution is to have the device driver dynamically adapt to network conditions and adjust the read-ahead cache on the fly. The capability exists right now but the rules/heuristics for when to increase or reduce the cache are difficult to create, hence the current solution of a more controlled benchmark.
(In the source code I have a histogram function and other counters that allow me to detect how much time is spent spinning waiting for a response to be received. A short spin time indicates a fast connection or a slow machine. A longer spin time indicates that there is time available to process read-head packets, and that the read-ahead cache size should be increased. If I get time I'm going to build a control loop based on that.)
Reply 357 of 434, by _Krille_
mbbrutman wrote on 2025-07-15, 15:48:
This is simply not possible. Once the device driver has initialized, its size can not be changed.
How is the read-ahead cache handled on the server side? Are the packets all sent as fast as possible or are there delays inserted between packets?
Reply 358 of 434, by _Krille_
Grzyb wrote on 2025-07-15, 12:54:
A better solution is to provide the read-ahead cache size as a parameter on the CONFIG.SYS command line. Then you can decide yourself exactly how much memory you want to spend on the read-ahead caching. In other words, a compromise between transfer speed and memory usage. The next (not yet released) version of my driver works this way.
Reply 359 of 434, by Grzyb
_Krille_ wrote on 2025-07-16, 22:13:
I guess the idea is not to change the DRIVER size, but only the CACHE part.
Unfortunately, can't avoid wasting memory when current cache size is lower than the maximum reserved in the driver.
