The Ultimate 486 Benchmark Comparison
Reply 360 of 377, by Eep386
I like how this thread slowly morphed into a "show off your otherwise stock high-clock 486 rigs" thing. Not complaining, just an observation.
TBH the "ultimate ___" meme, in 2026 at least, is strictly for market speculation purposes anyway.
Anyway, I might as well post the results I get with my MV035F-based Am5x86-P75 setup, running on 40MHz FSB at 160MHz.
Motherboard: EDOM/Wintech MV035F /w OPTi 82C802GA chipset
CPU: AMD Am5x86-P75 running at "P90" equivalent speed, 160MHz; 40MHz FSB
RAM: 16MB 30-pin FPM SIMMs
Cache: 256KB, dual-banks, made out of UMC data SRAMs and a wonky little Winbond 16Kx8 TAG
VGA: Cirrus Logic CL-GD5434 VLB, 2MB FPM
Sound card: Some ESS thing, due to be changed to an OPTi 82C930 (due to me needing a second IDE interface for the optical drive)
HDD: Quantum Fireball 540AT 516MB thing
OS: Windows 95 RTM upgraded to 'OSR 1'
Results:
3Dbench 1.0C: 82.5 FPS
PCPlayer benchmark: 21.1 FPS @ 320x200, 7.8 FPS @ 640x480
Doom timedemo: 2134 gametics in 1641 realtics (FastDoom knocks this down to 1076 realtics)
Speedsys: CPU: 58.22; RAM: 92.46MB/s L1, 54.90MB/s L2, 32.97MB/s off-cache; VESA Memory: 2048KB (15765 KB/s), HDD: Average/Max seek 10.39 / 15.27 ms, Random seek: 8.53 ms, Track-to-track 2.18 ms, Random access 15.88 ms, linear verify speed 1878KB/s
Cachechk:Reading: 1-16KB 7 uS/KB, 32-256KB 15 uS/KB, off-cache 29 uS/KB; Writing: 20 uS/KB across the board; Results: 164.9MB/s L1, 74.4MB/s L2, 38.4MB/s off-cache
Pretty hum-drum compared to the garish (meant in a good way) results common of this thread, but it sure feels nice. The OPTi 82C895/801/802 isn't about to win any benchmark awards for its stellar off-cache throughput, but it handles 40MHz FSB reasonably well once you've sussed the cache (dual banks or bust). Long-term longevity remains an open question mark. We'll see if this one disintegrates at high FSB like so many SiS and UMC 486 chipsets do.
Reply 361 of 377, by JAKra85
I want to enter in this Ultimate 486 Benchmark Comparison with: "The Monster!" 😁 (Am5x86@200MHz@50MHz BUS)
Results:
PCPlayer benchmark: 23.2 FPS @ 320x200
Doom timedemo:
On min. details: 337FPS
On max. details: 128FPS
(Edit: These Doom numbers look very suspicious on the S3 Virge with corruption visible, could not replicate with ATi 3D Rage IIC. Made screen pictures so this is what it was reported... Will check again later.)
Speedsys:
CPU: 74.97;
163.17MB/s L1
50.41MB/s L2
37.42MB/s off-cache.
Quake timedemo: 17,8FPS
Edit:
Not done tinkering: with 512K cache and ATi 3D Rage IIC (PCI) I got Quake: 18.6 FPS!
(no more corruption either!)
The attachment 20260914_111552.jpg is no longer available
Edit II:
Am5x86-P75-S @ 200MHz + ATi Radeon 7000 (PCI) 64MB DDR
Fully stable in DOS (so far).
The attachment 20260914_114953.jpg is no longer available
(Quake is still 18.6 FPS. Need better SIMMs)
Just completed today:
Re: I think I found a unicorn! Am5x86-P75-S @ 200MHz @ 3,45V (Edit:Now I really did!)
Still need better SIMM modules and better(?) video card that might handle PCI@50MHz with no artifacts. 😁
Retro PC Gallery:
https://docs.google.com/document/d/1ara32t4rV … nU/edit?tab=t.0
Reply 362 of 377, by feipoa
Your Quake results are sub-optimal for a hot rod 486 at 200 MHz. Maybe try to optimise at 180 MHz first. My Am5x86-180 gets 21.1 fps in DOS Quake.
Reply 363 of 377, by JAKra85
feipoa wrote on 2026-09-14, 11:25:
I agree and I *think* I am hindered by these RAMs.
For this PC I think this is very low. Bandwidth is ~88MB.
I've had better on a different mainboard @100MHz.
The attachment 20260913_225333.jpg is no longer available
As I've seen while testing timings and stuff that Quake is very memory/cache sensitive.
Retro PC Gallery:
Reply 364 of 377, by Babasha
JAKra85 wrote on 2026-09-14, 12:27:
I agree and I *think* I am hindered by these RAMs. For this PC I think this is very low. Bandwidth is ~88MB. I've had better on […]
As I've seen Quake while testing timings and stuff is very memory/cache sensitive.
8MB RAM is not optimal for Q1 (I use 32-64MB of fast FPM RAM), VESA memory bandwidth with S3 VIRGE/DX is up to 28000 if VIRGE/DX clocked up to 75MHz (I use MCLK utility)
Overall CACHE/RAM performance very depends on BIOS settings so pls give us screenshots of their settings
Need help? Begin with photo and model of your hardware 😉
Reply 365 of 377, by JAKra85
Babasha wrote on 2026-09-14, 12:33:
This is the best I could do. Swapped RAMs from another system. Now: 2x16MB (60ns).
Using 1WS on DRAM. With 0WS it does POST but won't boot.
Almost 20FPS. 😀
The attachment 20260914_145803.jpg is no longer available
The attachment 20260914_150056.jpg is no longer available
The attachment 20260914_150415.jpg is no longer available
Retro PC Gallery:
Reply 366 of 377, by Babasha
JAKra85 wrote on 2026-09-14, 13:11:
This is the best I could do. Swapped RAMs from another system. Now: 2x16MB (60ns). Using 1WS on DRAM. With 0WS it does POST but […]
Almost 20FPS. 😀
Not so bad
Anyway BIOS is not not adjustment rich
What motherboard do you use?
Reply 367 of 377, by JAKra85
Do you run the RAM at 0 WS? What are the cache specs?
Retro PC Gallery:
Reply 369 of 377, by Babasha
JAKra85 wrote on 2026-09-14, 15:03:
Babasha wrote on 2026-09-14, 14:40:
Not so bad
It's this Soyo board:
https://theretroweb.com/motherboards/s/soyo-sy-4saw
Can you try attached by me BIOS ?
It requires to be flashed in 29EE010 flash chip (not OTP ROM chip)
Reply 371 of 377, by feipoa
JAKra85 wrote on 2026-09-14, 15:02:
Single stick of 64 MB EDO, I think 50 or 60 ns using TSOP chips.
DRAM at 1 ws read, 0 ws write
SRAM at 2-1-2
Reply 372 of 377, by Intel486dx33
Is an AMD 5x86 in the same category as an 486 CPU ?
Reply 373 of 377, by H3nrik V!
Intel486dx33 wrote on 2026-09-23, 19:50:
Basically it's a 486 core.
Thread starter also includes it in the original benchmark data set as per: Re: The Ultimate 486 Benchmark Comparison and download/file.php?id=9211
Reply 374 of 377, by manton-ro
Hello
i am new on Vogons community, aplogize if this is not the right topic to ask.
I bought an Intel 486DX4-100 (Green letters) cpu and i want to ask what can a be a very good motherboard to build the system
Many thanks
Reply 375 of 377, by Babasha
manton-ro wrote on 2026-10-01, 15:10:
Hello […]
Hello
Many thanks
Something like Lucky Star LS-486E - not so rare and very trouble-free
Reply 376 of 377, by manton-ro
Thank you, i think i found one on eBAY.
Reply 377 of 377, by Eep386
How's about something a little different: A Pentium Overdrive 63Mhz setup, but running at an odd 30MHz FSB? CPU runs at 75MHz.
The attachment IMG_1493.JPG is no longer available
Quake gets 15.8 FPS in Mode 13h. VGA card is my CL-GD5434 VLB with 2MB.
DOOM timedemo gets 2009 realtics, with the screen size set all the way to the right (biggest).
