AMD K6 3DMARK, aiming for stars.
Reply 380 of 560, by Mentat-vvo
bloodem wrote on 2022-02-08, 08:12:
supercordo wrote on 2022-02-07, 15:42:
Does anyone know what the highest score is for MVP3?
You can find some here
My guess is that the fastest scores can be achieved with VIA MVP3 boards that support FSB frequencies higher than 100 MHz (i.e. Epox boards like the EP-MVP3G5). Couple that with a bit of fine tuning and I'm sure that you can get pretty close to 5000 points in 3DMark 2000. 😀
5000+ I got with mvp3 overclocked gf3ti200 and fine-tuned registers with 1mb cache @124M bus, here in the thread. K6-3+ mobile @ 624M. No driver glitches, no cheats. Just raw power. To add support to gf3 to the driver one should mod the inf file.
PPro250/Freeway694x/512M/Gf3Ti500/AdvGUS
2x P3Xeon900-2M/1Gb/QuadroDCC/AWE32
K6III+400@624/P5A/256Mb/GF3ti200@500
Iskra 1031 Issue 2 - i8086 PC/XT Clone from USSR
Reply 381 of 560, by cyclone3d
Sphere478 wrote on 2022-02-17, 05:23:
Someone mentioned that the high scores you guys are getting are from a driver glitch not actual gained performance? What are your thoughts on that?
Back in the day, Nvidia was caught with cheaty drivers which gave artificially high scores in 3dmark. I don't know what drivers versions were like that but it should be pretty easy to find.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 382 of 560, by Sphere478
I’ve encountered a road block that is really turning me off to these cards. I got the gf3 ti500 to do a bench on xp but it’s doing no better than my radeon 9800 pro using the forceware 40 driver.
Someone suggested a driver earlier but I can only find it for 9x
Anyone have a good xp driver link?
Another thing, my monitors are all digital. And these cards refuse to work on dvi in dos or 9x or bios on dvi
Sphere's PCB projects.
Reply 383 of 560, by Doornkaat
Sphere478 wrote on 2022-02-20, 05:35:
I’ve encountered a road block that is really turning me off to these cards. I got the gf3 ti500 to do a bench on xp but it’s do […]
I'm attaching Nvidia Detonator XP 27.30 It's from January 2002 and VEN_10DE&DEV_0202 is listed in nv4_disp.inf so your GF3 500 Ti should be supported.
Can't say wether this is a good choice for this specific card and platform though.
Edit: Reading your post again I'm not sure wether you were asking for an earlier driver or a specific driver that was suggested earlier. Anyway, this should be one of the earliest drivers with official support for your card and XP, and since it's from roughly a year after the NV20 released it should be mature.
Reply 384 of 560, by Doornkaat
Here's version 23.11 for 2k/XP in case you want to test that too. It's dated 11/29/2001 and GF3 500 Ti is listed as well.
Had to extract the original executable and compress the files with 7zip because the original exceeds upload limits.
    Win2K-XP_23.11.7z
    4.51 MiB
    50 downloads
Reply 385 of 560, by Sphere478
Sweet! Thanks! I’ll try em 😀
As for what I’m looking for, the best performing one under xp. And 9x.
Separately I’m trying to figure out how to get them to show anything prior to loading windows xp. I hope I don’t have to end up getting a upscaler.
edit:
OH MY CRAP,
We now have a way to enable cache on k6-2+ to full 256k
Reply 386 of 560, by Necrodude
Sphere478 wrote on 2022-02-21, 05:24:
OH MY CRAP,
Wow! Awesome. Well done! 😀
I ordered a batch of three from a ebay seller in the states!
Reply 387 of 560, by Sphere478
Cyrix/ST/IBM Aiming for the stars!
Can you guys throw a cyrix into one of your record setting rigs and report results? 😀
Reply 388 of 560, by bloodem
I did a K6-2+ to K6-3+ mod yesterday, and as I was testing the 'new & improved' CPU on a Gigabyte GA-5AA rev 3.2, I realized that this board got a pretty substantial boost in performance with those extra 128 KB of L2 cache that the CPU gained. The board's performance was pretty underwhelming with a K6-2+, but it gets pretty close to an Asus P5A when using a K6-3+.
So, without trying too hard and without any special fine tuning (just the usual Ali AGP changes), I was able to easily break the 5000 points barrier in 3DMark2000 at default settings (attached photo)
SPECS:
MB: Gigabyte GA-5AA rev 3.2
CPU: K6-2+ 570 modded to K6-3+, OC @ 633 MHz (FSB115 x 5.5)
RAM: 256 MB (this board has a "G" revision North Bridge with an internal tag RAM, it can cache up to 512 MB of RAM)
VGA: Asus V7700Ti (GeForce 2 Ti 64 MB, OC @ GeForce 2 Ultra)
I'm guessing that with a bit of WPCREDIT fine tuning and a GeForce 3 Ti 500, it might possibily hit somewhere around 5200 - 5300 points (maybe more?). Pretty insane!
If I ever find the time, will do some more tests in the future. 😀
    1.5 MiB
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 389 of 560, by Repo Man11
bloodem wrote on 2022-03-17, 10:32:
I did a K6-2+ to K6-3+ mod yesterday, and as I was testing the 'new & improved' CPU on a Gigabyte GA-5AA rev 3.2, I realized tha […]
SPECS:
Could you please post a screen shot of your Sandra memory benchmark?
Reply 390 of 560, by bloodem
I was just about to put the motherboard in the box 😁
Don't have Sandra, but I've attached the Aida64 cache & memory benchmark (I hope that's OK).
The memory numbers are a bit better than what I got with the Asus P5A in the recent video that I uploaded, but then again, the Asus was running @ FSB105, while the Gigabyte is @ FSB115 (also the Asus had a K6-2+, but that should not matter for the memory tests).
And since I powered on the motherboard again, also did a quick 3DMark99 run.
    1.43 MiB
    864.07 KiB
Reply 391 of 560, by Sphere478
Bow before the 66mhz fsb of the tyan s1564D and a measily radeon 7000! (Score doubles with radeon 7500 🤣)
Reply 392 of 560, by Skalabala
SPECS:
Welcome to club 5000!!
Reply 393 of 560, by bloodem
Skalabala wrote on 2022-03-21, 19:05:
Thank you! But... I was already in the club for some years, since I bought my first Asus P5A board (which, to this day, is still my fastest). 😁
However, this is the first time I'm seeing over 5000 points with a non-Asus board (TL;DR, not sure if anyone else in this thread got over 5000 points with a non Asus board).
Reply 394 of 560, by Sphere478
Are any of you guys able to use dvi on your gf2/3 cards in the bios?
That’s the main reason I’m not using mine it’s super annoying
Reply 395 of 560, by bloodem
Sphere478 wrote on 2022-03-22, 10:48:
DVI on these early GeForce cards is virtually unusable for me (from an image quality standpoint). This is especially noticeable during POST and in DOS, where everything is a blurry mess.
ATI cards, on the other hand, have a very nice and sharp image on DVI.
All in all, I prefer the VGA output. 😀
Reply 396 of 560, by Skalabala
bloodem wrote on 2022-03-22, 09:54:
Ah yes I remember now, well not many in 5000 with non Asus, there is VIA and then you with the Gigabyte.
I can not remember if I got 5000 with the GA5AX. I should have been close at least but the G rev is faster than E.
Reply 398 of 560, by bloodem
Necrodude wrote on 2022-03-25, 19:37:
What do you guys get with Vanilla Quake3 stock settings?
Demo four.
This is what I got with the most recent SS7 platform I tested (Asus P5A rev 1.04 + AMD K6-3+ 570 @ 633 MHz): https://youtu.be/jrV6vPGR3Yc?t=1570
