Reply 40 of 47, by 385387386
Babasha wrote on 2024-05-01, 10:52:
https://www.cpu-world.com/CPUs/Pentium/Intel- … 20PODP5V83.html
PODP5V83 - where Pentium OverDrive Processor 5V 83MHz?)))
Oh! I always set the voltage to 3.3v, until then I increased to 4v......
I jump the wrong setting.......
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Now upgraded to Cyrix MII 291.5MHz (maybe PR400)
Reply 41 of 47, by CoffeeOne
385387386 wrote on 2024-05-01, 10:36:
Now, POD83 @83MHz running quake at 19.3 frames per second with fake cache.
Great!
As already mentioned, those quake values are not really useful, you have to repeat it with a PCI graphics card.
Reply 42 of 47, by CoffeeOne
Yes, it is a upgrade CPU, so it works on 5 volts only mainboards.
On the other hand, the CPU supports also voltage detection, so when the mainboard provides the 3.5 volts, the voltage regulator on the cpu is not used.
Why it works now with 4 volts setting is not clear.... But not very important I think.
Reply 43 of 47, by 385387386
CoffeeOne wrote on 2024-05-01, 11:05:
Great!
Thanks. Very exciting to get 83MHz back.
OK, I will do more test.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Reply 44 of 47, by 385387386
CoffeeOne wrote on 2024-05-01, 11:08:
Yes, it is a upgrade CPU, so it works on 5 volts only mainboards. On the other hand, the CPU supports also voltage detection, so […]
This means an average POD83 can run on normal voltage settings as AMD DX5.
My first PC (1997)
IBM 6x86mx PR200
BIOSTAR M5ATA
16MB SDRAM
Reply 45 of 47, by maxtherabbit
I don't think that's true, you have to provide it 5V for correct operation
Reply 46 of 47, by CoffeeOne
maxtherabbit wrote on 2024-05-01, 11:32:
What would be then the purpose of the VOLDET pin on the CPU?
Reply 47 of 47, by majestyk
As far as I understood, VOLDET tells the mainboard, weather a 5V CPU is present or not. But can it tell the CPU weather the socket provides 5V or 3.45V??
