First post, by 385387386
I just got a pentium overdrive PODP5V83, but the manual of M915i motherboard have no mention about P24T.
Is there a hidden jumper setting on M915i for P24T? Thanks.
Reply 1 of 47, by dominusprog
Set the jumpers for DX2-66.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 47, by 385387386
Really exciting! The Pentium OverDrive 83MHz works!
    389.99 KiB
    I will replace the fake cache with real 1MB cache.
    437.55 KiB
    Fake Cache.
    332.6 KiB
    Pentium OverDrive 83MHz with M915i Success!
Reply 4 of 47, by dominusprog
Glad it worked out! You have a very nice setup there.
Reply 6 of 47, by CoffeeOne
385387386 wrote on 2024-04-23, 13:58:
Is this a modified Pentium Overdrive? Without fan normally it will run only on 33MHz, so with multiplier 1. That would be slower than a DX2-66, but still good to install Windows XP, haha.
Where did you get those Winbond W241024AK-15 chips from?
Good luck for the replacement job. Maybe it will be a good idea to install sockets.
EDIT: The exact same serial number on all 12 chips looks a bit suspicous. I am afraid you are going to replace fake cache with fake cache.
Reply 7 of 47, by 385387386
CoffeeOne wrote on 2024-04-23, 18:14:
Is this a modified Pentium Overdrive? Without fan normally it will run only on 33MHz, so with multiplier 1. That would be slower […]
I found the chip on a B2C website (taobao).
Yes, can not rule out all the chips are still fake. I'll try. The corresponding 32dip sockets are really really hard to find, maybe I can use double 16pin dip socket instead.
I'm thinking use pencil trick may get the frequency back. Very interesting to see running Windows XP on a 486 platform. And I predict the OS should be very slow even frequency on track
And the Pentium Overdrive 83 is little bit odd, there's no marks on the backside.
    131.31 KiB
    No marks on the back side.
Reply 8 of 47, by 385387386
dominusprog wrote on 2024-04-23, 15:23:
Yeah. Thanks.
I will find an old AT keyboard to get through the post to check whether the board's old BIOS can display the Pentium OverDrive correct or not, since the post stuck there with keyboard error.
Reply 10 of 47, by majestyk
385387386 wrote on 2024-04-23, 23:49:
majestyk wrote on 2024-04-23, 16:04:
And I´m confident 1MB L2 cache will be capable to cache the whole lot of 4MB RAM 😉
Maybe 256MB RAM will also covered 😉
...in write-back mode, of course 😒
Reply 11 of 47, by majestyk
majestyk wrote on 2024-04-24, 09:01:
...in write-back mode, of course!
Reply 12 of 47, by 385387386
Glued 6 small heatsinks on the top.
    288.62 KiB
    262.44 KiB
Reply 13 of 47, by 385387386
majestyk wrote on 2024-04-24, 09:02:
I'm not sure it can really support write back mode.
Reply 14 of 47, by dominusprog
385387386 wrote on 2024-04-26, 23:44:
Install a 20x20mm fan on the heat sink, just to be on the safe side.
Reply 16 of 47, by 385387386
CoffeeOne wrote on 2024-04-27, 14:44:
Does it now run at 33 or 83MHz?
33MHz, I try to short the GND dot and Sensor dot with a wire, but it failed to boot. Any way to work around to get 83MHz back? Thanks.
Reply 17 of 47, by 385387386
dominusprog wrote on 2024-04-27, 13:50:
Okay, I'll install a fan on top.
Reply 18 of 47, by majestyk
385387386 wrote on 2024-04-26, 23:49:
I´m sure this UMC PCI chipset does support L2 write back mode. But if it is capable of cacheing 256MB RAM in write through mode, the cacheable area will probably be 128MB in write back mode.
Reply 19 of 47, by 385387386
majestyk wrote on 2024-04-28, 06:38:
That's great, 256MB memory on the way.
