Reply 40 of 47, by Spitz
- Member
Sure You can just leave s478 era setups without intel chipset drivers and it will work... Yeah "work". But many mainboard companies didn't issue drivers for their chipsets! And If you think that Intel standard chipset (ICH2...3...4...etc) drivers gives the solution then... How how wrong You are!
What I'm saying... If someone propose tonturn s478 rig into 98retro machine then I'm just wondering what is doing my SP3 XP byMalcomX (last winxp!) on hdd of my P3 1.0ghz 512MB and Voodoo3? Which runs great.... .... Last 3 MB from P4 800mhz FSB 3.0Ghz that I tried to run under W98 failed, because of lack of drivers or and unstability... Dont tell.me that a setup from 2004/2005 will go good with system that ended support on +/-2002! ... Tried with bad experience! XP is perfect for s.478 in total of support=stability.. that's all. P.s. try to install NV 6800/7900 AGP on a win98 = good luck! And If somehow You manange to do this report about glitches and speed under 98!
And little sth at the end... Try to install w98 on 6800+ s478 and try to pass the first screen after scandisk procedure .... Sure it will let You through without stuck black screen.
Well... I miss 80/90s ... End of story
