Reply 40 of 53, by DEAT
A fairly significant update has been uploaded to the site today - I have added icons for almost every game (except for those that require a runtime EXE, such as Asymetrix ToolBook and KnowledgePro) and also kept track of icon changes between versions. I've limited it to 50 icons per page because a small number of games have (almost) all of their images as icons - Castle of the Winds has 236 of them in the shareware episode, and 288 in the registered episode! I've also added information regarding language support, minimum RAM, multiplayer support (a few games are ambiguous and will need further testing) and consolidated additional runtimes into a single field for each page for future proofing.
On the index page, you can now browse by multiplayer support, language, minimum Windows version, minimum RAM, and additional runtimes. Browsing by minimum CPU now lists multiple entries of games if different versions have different CPU requirements instead of whatever the lowest CPU was in total. Minimum video has now been changed to video support in general.
Finally, a bunch of minor updates have been made to several pages - check the updates page for more details.
win16.page | Twitch
Reply 41 of 53, by WolverineDK
DEAT wrote on 2025-06-13, 06:46:
I really enjoy watching and reading your site. And I think it is a fantastic piece of work you are doing. Also you mentions icons (game icons I presume). I must point out, that irfanview on Windows can extract some of those icons from the exe files. Anyway keep up the great work ! 😀
Reply 42 of 53, by MrFlibble
I have a question to the fine community here, how do you go about running these Win3.x titles on modern high-res LCD displays? From what I understand, not all of them will stretch the image to desktop resolution (and if they do, the proportions will likely be wrong), and many simply do not have any proper fullscreen mode.
I'm not happy with the solution to use DOSBox/other emulator + a copy of Win3.1, since I don't have one and there is no legit way to get ahold of one currently.
I haven't used Wine in a while, so I'm not sure if it supports any kind of out-of-the-box scaling, but perhaps there is a way to switch to a lower resolution when running? On Win10, I use winevdm, which definitely does not provide such a feature, although I think you can configure an EXE to switch to 640x480 as part of the legacy mode or something. I haven't tried this out yet though.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 43 of 53, by Jo22
Hi there! My "trick" with hi-res LCD monitors is to try to use 800x600 resolution.
Because a big 4:3 monitor panel often uses 1600x1200 natively,
which is two times the resolution (2x2 or 4x the pixels).
It also has the advantage that many Super VGA games on DOS had supported 800x600 16c.
Especially flight simulators, city sims or graphical adventure games (Magnetic Scrolls, Legend Entertainment games).
Windows 3.1 has an 800x600 16c driver shipped, as well, which works with modest 256KB VGA cards, even.
WfW 3.11 has an additional 256c driver for 640x480/800x600/1024x768 as well.
- If possible, using 256c on Windows 3.1x is favorable also. It supports palette cycling, most importantly.
Another advantage is that 800x600 resolution has a reasonable information density,
but same time isn't making Windows GUI elements too tiny.
Many Windows games (such as Warpath!) had the option to expand the play area to about 800x600.
The flight tower simulators for Windows 3.0 looked less crowded on 800x600, too: Tracon for Windows aka ATC: Air Traffic Controller
So yeah, Windows 3.1 often is being remembered for Standard VGA in 640x480 16c, but 800x600 16c was recommended in practice.
It's like as with minimum requirements and recommended requirements.
Windows for Workgroups built on this by making 256 colours a common minimum colour depth, thanks to its universal 256c SVGA driver(s).
Games using WinG or QuickTime or playing FMVs via Video for Windows do benefit from 256c, for example.
GIF files can be fully viewed in 256c, as well. And 256c allows for 20 Windows system colours, rather than just 16.
But that's just my opinion, of course.
800x600 wasn't an ideal resolution, but it's a historical compromise that's acceptable, I think.
If it was IBM, then 640x480 and 1024x768 are the standard resolutions (IBM 8514/A used these resolutions).
Way back in the mid-80s, many EGA cards had the ability to go up to 800x600 16c on a "multisync" monitor.
A monitor that's more of a general-purpose monitor rather than an EGA or VGA specific monitor.
Such universal monitors had been used in Japan with Sharp X68000 or PC-98, for example.
I mention this, because TV companies such as Sony came from Japan.
Edit: My comment was about using vintage hardware (such as a 486 PC) with a big LCD monitor.
In emulators, it might be a good chance to run sophisticated CRT pixel shaders! 😃
They need the highest resolutions anyway in order to simulate a CRT screen the most authentic.
Edit: If you're into Unix/Linux, you might also be giving WABI a chance.
Long story short, it runs a copy of Windows 3.1x 386 Enhanced-Mode kernal on the *nix kernel.
There's no DOS involved, it's just Windows 3.1x - with all its utilities.
WABI also supports Windows for Workgroups (both versions).
That way, you can run Windows environment on about any resolution.
(You need to have the required Windows 3.1x files, obviously.)
Edit: It's a bit like using WIN-OS/2, maybe. Except that there's no DOS VM involved.
Speaking of OS/2, Ecomstation and ArcaOS still have WIN-OS/2 included.
They're operating at high resolutions, too.
Reply 44 of 53, by MrFlibble
DEAT wrote on 2025-06-03, 01:47:
Can't state enough how much I appreciate these links - thanks a lot for sharing all of these.
I remembered one more source that is sadly down with no downloads, but it lists file sizes in bytes, as well as developer/publisher homepages in many cases.
It was the Italian site called VOLftp. They had a pretty big listing of downloads spanning across multiple pages and split into platforms (DOS, Win3.xx, Win95 and even Win98 as a separate subset). The lists themselves are available via the Wayback Machine:
http://web.archive.org/web/*/http://volftp.ti … /win3xx/games/*
As usual there were some mislabellings, so you might want to look under the Win95/Win98 folders too I guess (yeah, they also had WinNT separately too):
http://web.archive.org/web/*/http://volftp.ti … s/win95/games/*
http://web.archive.org/web/*/http://volftp.ti … s/win98/games/*
http://web.archive.org/web/*/http://volftp.ti … winnt50/games/*
Reply 45 of 53, by leileilol
Noticed the number of players and language fields are swapped
Reply 46 of 53, by DEAT
Updated the site! I've now added EGA screenshots to all games that support EGA, added the ability to browse by software license, and have set up category browsing to be split into 50 games per page which should be a lot more friendly for Windows 3.1-era hardware. There's also several minor corrections to pages, which are all listed in the updates page.
With that said, I'm now satisfied with what is documented on the site per game and the categories that are available for browsing - the only thing I want to do that is worthy of documentation is joystick support, which I will get around to with the next update. There's also some games which I haven't listed missing versions for yet, but I'll get to that later. The next update with new games should be happening during September.
MrFlibble wrote on 2025-07-03, 13:34:
It was the Italian site called VOLftp. They had a pretty big listing of downloads spanning across multiple pages and split into […]
Thanks for this, this is a great source! Much appreciated as always.
leileilol wrote on 2025-07-07, 19:26:
Oops, thanks for that! Good thing I checked the thread just before I made this post to fix that
win16.page | Twitch
Reply 47 of 53, by Jo22
Hi, looks very good! Thank you very much! I also like EGA's palette. 😃
About joystick support, there's an optional joystick applet (IBMJOY, by IBM?) for Windows 3.1x.
It can be installed like a device driver via Control Panel, you likely know about it already.
Not sure how many Windows games do use it, though. I can only guess. 🤷‍♂️
I would think that some games do/did just talk directly to gameport like on MS-DOS, but I'm not sure..
On other hand, "modern" Windows 3.1 games from mid-90s likely know about the applet/driver.
The type of games from days of QuickTime, Video for Windows, Win32s etc. I mean.
They got released when multimedia was at its height and users at advanced 486/Pentium PCs, so to say.
When emulators and arcade packs got released for Windows 3.1/95, too..
By that time, software developers also did cross-platform development (Mac System 7/Windows)
and using libraries for hardware abstraction started to make sense, I guess.
Btw, there seems to been other joystick drivers, too,
according to this old discussion
- megadwat.zip (Atari 2600 and Sega MD/Genesis joystick interface)
- watjsnes.zip (NES/SNES joystick interface)
Reply 48 of 53, by DEAT
Jo22 wrote on 2025-07-15, 07:17:
Yep, there's a few games already on the site that include the IBMJOY driver - I just haven't got around to testing it yet.
Interesting point about direct joystick access - I'll have to do some digging with that as well.
Examples I know of that are currently on the site are Comet Busters!, Hit or Miss, Runner and the Schenk & Horn block games (Colorstar 2000, Magic Words, WinBlocker) - I'm expecting when I get into the later era games that the number will increase by a fair amount.
Emulators are on the to-do list, I'm aware of your thread here on VOGONS 😀
I have found a few alternate versions, just haven't spent enough time checking their actual functionality. Ancient versions of Stella (v0.57, v0.6, v0.61) almost work, but spit out a Win32s error when trying to play a game.
I did spend a good amount of time a couple years ago creating .NES to Pasofami conversions, which I got sidetracked on - the metadata files should be fine to upload to the site.
Btw, there seems to been other joystick drivers, too, according to this old discussion - megadwat.zip (Atari 2600 and Sega MD/Ge […]
This is good info, I'll have to dig into this further!
win16.page | Twitch
Reply 50 of 53, by BinaryDemon
Have you considered adding non-game freeware? Love the site, it would just be nice to find everything 3.x in on place.
Reply 51 of 53, by doshea
The site's certificate expired about 2 weeks ago.
Reply 52 of 53, by bocke
I recently found a game demo for "Muppet Treasure Island" on a shareware CD-ROM. It was released in 1996 in parallel with the movie ofthe same name. In its directory it had a copy of WING and binaries for Windows 3.1 and Windows 95. I also found the full version and it still contains WING.
The magazine was Personal Computer World, release from the January of 1997 (avaliable on Archive.org).
WING games are kinda badly documented, so that's why I am posting here as you have a separate category in your database for them.
Reply 53 of 53, by marxveix
First it was not possibe to open website with chrome, but chrome://net-internals/#hsts and Delete domain security policies at win16.page delete helped.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
