Hey, things start moving again!
So good to know, the ISL6525 was a goner. Alright. NVVDD is 1.6V, should be 1.66V, so good enough I'd say. We're clearly missing the memory voltages.
FBVDD (main memory voltage) should be 2.8V.
VTT (derived from main memory voltage) should by around 1.2V.
Let's check a couple of things (perhaps even in that order).
- State of NVVDD_PWRGD - pin 7 of the NVVDD regulator ISL6525 (during operation) - if that one is not high, the memory regulator will stay offline.
- Resistance of FBVDD against ground (not installed into a system)
- Resistance of VTT against ground (not installed into a system)
- Voltage on R1285 (both sides) should be around 5V - (during operation)
- Signals on R1291 (low FET gate for FBVDD) as well as for R1292 (high FET gate for FBVDD) - (during operation)
We're looking at the ISL6225 now, which is a dual output buck converter built for memory power supply applications:
The attachment isl6225.pdf is no longer available
We'll figure it out.
I've noticed that your riser cable introduces a significant drop on the 3.3V apparently, if only 2.4V remain at the card. 😉
