Screeching when running DosBox
Reply 40 of 44, by marooned_on_mars
Bummer 😒
Oh well, thanks for your help! I guess I'll leave it this way until I can get a new soundcard 😜
Or perhaps I could contact SDL devs in case they know a solution. (unless the power saving switch you mentioned might do the trick)
Anyway, in case anyone needs to make this modification, I made a diff patch with all the modifications:
The attachment busyWait-patch.diff is no longer available
Reply 41 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
The only one you need is the one in dosbox.cpp.
I have been considering adding something like this to fool the cpu scheduling on linux, however messing with the cpu governer works as well. (On my machine using the cycles=max 105% is enough to fool it.)
just google for linux cpu governor and pick your distribution, you want to have the performance one 😉
* I changed the topic title to its nornal name.
Water flows down the stream
Reply 42 of 44, by marooned_on_mars
I think you misunderstood, I don't want it to take up 100% of the CPU 😜
This is for DosBox with busyWait or without?
But you didn't move the thread in it's appropriate subforum 😜
Reply 43 of 44, by Qbix
Rank DOSBox Author
DOSBox Author
for normal dosbox and I didn't move it, because of reasons 😉
Reply 44 of 44, by marooned_on_mars
Completely forgot about this thread. Setting the governor to performance didn't fix anything, I can still hear the noise through the headphones. I also asked on the SDL community forums for a solution, will post here if I get an answer.
