First post, by marooned_on_mars
- Member
I've never encountered any app/program to do such a thing, but whenever I run DosBox I hear a continuous high-pitched screech/hissing through my headphones (I can also hear when the HDD spins, but it's not that loud, this probably indicates an issue with the way the jack sockets are wired) but also up close to the unit. It's not extremely loud but it can still get quite distracting and annoying after a while (much like how annoying are bad camcorders when they leave behind a sort of a ringing sound in the background when recording). At first I thought it might be an issue with SDL and my rig, but that's not the case, as I've tried other SDL apps (like ScummVM) and this doesn't happen.
Here are the following things that I tried as a way to diagnose:
- DosBox on both Windows and Linux. It's a bit less louder on Windows, but still annoying.
- Compile DosBox myself from either 0.74 source code and latest SVN
- Used ykhwong's builds
- Got DosBox from the Debian repos
- Increased/Reduced cycles. Interestingly when I would go below 2000 cycles, the pitch would go lower progressively
- Changed between video output types
- Changed between the core types
- Changed between machine types
- Changed audio sample rate
- Changed blocksize
- Disabled all sound sources
None of the above did change anything (except with the cycles example), so now I'm sitting here and wonder what exactly is causing this. Any help would be really appreciated.
