Reply 40 of 97, by F2bnp
Exactly! Thanks for the downloads Phil, 2.41 seems to work, however I found out that my HDD is operating rather slowly, thanks to the VIA chipset. UDMA2 (ATA 33) instead of UDMA5 😵 . I'll see if I can fix it at some point, but I'd have to mess around with VIA 4in1 black magic and I ain't really in the mood. In the meantime, here are some results:
PC specs:
PIII-S 1.4GHz + Thermalright SLK-800 cooler
512MB RAM CL3
QDI Advance 10T
3Dfx Voodoo 5 with latest non-beta drivers
Aureal Vortex 2 with 2041 drivers
Western Digital 250GB HDD (138GB usable)
WinME
GLQuake
640x480:329.4 FPS
800x600:247.3 FPS
1024x768:164.5 FPS
1280x1024:106.9 FPS
1600x1200:76.4 FPS
Quake 2
640x480: 228.4 FPS
800x600: 204.9 FPS
1024x768: 156.9 FPS
1280x960: 107.9 FPS
1600x1200: 65.3 FPS
Unreal
640x480: 156.45 FPS
800x600: 136.62 FPS
1024x768: 109.33 FPS
1280x1024: 72.37 FPS
1600x1200: 50.81 FPS
Unreal Tournament
640x480: 94.85 FPS
800x600: 93.68 FPS
1024x768: 90.61 FPS
1280x1024: 72.85 FPS
1600x1200: 53.17 FPS
Forsaken
640x480: 383.69 FPS
800x600: 313.19 FPS
1024x768: 237.74 FPS
1280x1024: 164.21 FPS
1600x1200: 117.47 FPS
Reply 41 of 97, by anthony
I'd rather prefer bx board. Voodoos tolerates 89mhz bus very well. And bx outperforms 815 easily. 815 is good for serious overclocking
Reply 42 of 97, by calvin
440BX? i815? You wimps should consider i820, with Rambus(t)!
2xP2 450, 512 MB SDR, V3 2000, Asus P2B-D, Windows 2000
P4 2.6, 2 GB DDR1, Radeon 9600 Pro, P4P800, Windows XP
Alpha 21164, 512 MB, Permedia 2, KZPCM, AlphaPC 164, NT 4.0
Reply 43 of 97, by F2bnp
Agreed! There was someone here that bought one such board fairly recently. Can't remember the guy's name, maybe he can drop in to offer some benchmarks !
Reply 44 of 97, by PhilsComputerLab
UDMA2? That's odd. Oh I do remember something. On my Gigabyte board, there was a BIOS option to do with the ribbon cable. I had to set it manually to ATA66/100 or something like that to get top performance. So check if you have something similar.
I've used 440BX boards with Pentium III 1.1 GHz in my Voodoo shootout reviews: http://www.philscomputerlab.com/3dfx-voodoo-s … ut-project.html
Love that chipset. But I'm not into overclocking. So for me, a stock Tualatin ends up faster, mostly thanks to the massive 512 KB Cache. It was easier for me buying a Tualatin motherboard than getting a Tualatin Slot 1 adapter.
I don't have anything with RAMBUS. Sounds like fun, but also expensive.
YouTube, Facebook, Website
Reply 45 of 97, by calvin
It's a bit higher end. My Dimension with an i820 supports 1 GB, but I only have 512 MB RAM installed. Also remember terminators.
Reply 46 of 97, by F2bnp
Felt like going the extra mile and ran some overclocked CPU benchmarks. I set the FSB to 150MHz, so the CPU is running at 1575MHz.
GLQuake
640x480: 339.6 FPS
800x600: 247 FPS
1024x768: 164.5 FPS
1280x1024: 106.9 FPS
1600x1200: 76.4 FPS
Quake 2
640x480: 254 FPS
800x600: 209.3 FPS
1024x768: 157.3 FPS
1280x960: 107.9 FPS
1600x1200: 65.3 FPS
Unreal
640x480: 168.41 FPS
800x600: 142.86 FPS
1024x768: 110.4 FPS
Unreal Tournament
640x480: 105.17 FPS
800x600: 103.80 FPS
1024x768: 97.62 FPS
1280x1024: 74.80 FPS
Forsaken
640x480: 401.89 FPS
800x600: 325.61 FPS
1024x768: 243.77 FPS
1280x1024: 165.90 FPS
1600x1200: 118.92 FPS
The difference is minimal at best and it usually makes no difference even at 1024x768 which is what most people would play on with a V5 (or 640x480+2xAA which should be close performance wise). I really don't see the reason some people build Athlon XP-M builds for these cards, unless they're overclocking the GPUs quite a bit.
Interested in seeing how the 440BX fares. I'd love to get my hands on the QDI Advance 12T someday 😈 !
Reply 47 of 97, by PhilsComputerLab
Nice scores!
Here are my benchmark results with a 440BX and Pentium III 1.1 GHz (100 MHz FSB). As you said, at higher resolutions, bugger all difference.
Reply 48 of 97, by subhuman@xgtx
Some missing(!) results. It's about 2:15 am and I really want to sleep a little ^^ I wanted to share with you what I had by now though, will update the post tomorrow 😀
Athlon XP2500M@ 2.3
1GB DDR400 RAM
Win98SE
Voodoo5 (latest official drivers)
Unreal
Voodoo5 @ 166MHZ (stock)
640x480: 213,84 fps
800x600: 156,91 fps
1024x768: 115,22 fps
1280x1024: 75,491 fps
Voodoo5 @ 183MHZ
640x480: 228,59 fps
800x600: 171,06 fps
1024x768: 127,05 fps
1280x1024: 83,23 fps
Unreal Tournament
640x480: 144,38 fps
800x600: 138,75 fps
1024x768: 116,92 fps
1280x1024: 79,85 fps
Voodoo5 @ 183MHZ
640x480: 143,82 fps
800x600: 140,09 fps
1024x768: 124,54 fps
1280x1024: 87,63 fps
GLQuake
Voodoo5 @ 166MHZ(stock)
640x480: 346,1 fps
800x600: 243,0 fps
1024x768: 152,5 fps
1280x1024: 105,6 fps
Voodoo5 @ 183MHZ
640x480: 377,9 fps
800x600: 266,2 fps
1024x768: 173,1 fps
1280x1024: 115,1 fps
Quake II
640x480: 315,8 fps
800x600: 215,6 fps
1024x768: 160,6 fps
1280x960: 110,5 fps
Voodoo5 @ 183MHZ
640x480: 342,3 fps
800x600: 239,3 fps
1024x768: 177,7 fps
1280x960: 122,0 fps
Bear in mind I usually post to the forums using my old systems.
Reply 49 of 97, by PhilsComputerLab
Very nice results! Rest up 🤣 Zzzzz
Reply 52 of 97, by F2bnp
Evert, that was spot on 🤣 .
Great results subhuman, like I said previously, a faster CPU really pulls ahead at lower resolutions, especially on UE1 games which are very CPU dependent. I ran some overclocked Voodoo5 tests on my system too, at 177MHz (highest my card can do without artifacts), I didn't bother with low resolutions:
GLQuake
1280x1024: 112.9 FPS
1600x1200: 80.8 FPS
Quake II
1280x960: 114.6 FPS
1600x1200: 69.4 FPS
Unreal
1280x1024: 77 FPS
1600x1200: 54.11 FPS
Unreal Tournament
1280x1024: 78.28 FPS
1600x1200: 56.58 FPS
Forsaken
1280x1024: 176.26 FPS
1600x1200: 126.36 FPS
Reply 53 of 97, by PhilsComputerLab
I won't dare overclock the V5. Cost me a small fortune 😊
A little OT, but I'm working on a new project. Initially I was set on using a Matrox G400 Max card, because I always use Voodoo cards, you know do something different.
But I had lots of issues getting games to work. Went back to a V3. Everything works. It's indeed the gamers card of that period.
I don't know much about Nvidia and cards from that era. I hardly got any cards. I believe I have a GF3 and a few GF4 cards. Ti and MX.
Reply 54 of 97, by Evert
Well, do be honest, most cards from that era were troublesome and had horrible drivers, but that's really part of the fun... Getting the games to work and tinkering.
Reply 55 of 97, by F2bnp
philscomputerlab wrote:
I won't dare overclock the V5. Cost me a small fortune :blush: […]
The Voodoo5 has some pretty shoddy cooling and noisy fans. I bought one a few months ago from forum member and all-round awesome guy Stojke and he had replaced these with full copper heatsinks and quieter fans. Overclocking slightly isn't going to strain the card, since you're not touching voltages anyway. I can see why you wouldn't do it though 😜.
The Voodoo 3 is an amazing card, far more compatible than V5.
Reply 56 of 97, by anthony
if you, guys, can point me to benchmark tools you've used (i mean downloadable games archives), i can provide results for agp v5 on i865 with c2d
Reply 57 of 97, by PhilsComputerLab
C2D 😲
Nice 😀
Well, you got to have the games I'm afraid. But I have posted the instructions a page earlier or so.
Reply 59 of 97, by Evert
That's definitely something I'd like to do.
