WORKING Shuttle HOT-613 (Single to Dual - Pentium Pro)
Reply 40 of 74, by cyclone3d
Here is the BIOS update info for that board:
Bios-Update history for HOT-613 Mainboard
Attention:
This file may not be up to date.
We are not liable for any damages caused by the bios-update.
1) Check programming voltage of EEPROM
JP15 1-2: 12V (Intel and MX Chips)
JP15 2-3: 5V (generally: others than Intel chips)
2) Do not load any memory manager.
3) Start DOS and execute: AFLH52B <BIOS file name>
4) After programming, turn off your system for a moment.
The <Bios-Filename> depends on the I/O-Chip (U48) of the onboard-controller.
613WUQ09.BIN UMC-I/O-Chip
613WIQ09.BIN ITE-I/O-Chip
613WIQ09.BIN & 613WUQ09.BIN
add ZIP ,large size HD
613WIQ0A.BIN
dual processor bugfix
613WIQ0B.BIN
fix cannot assign PCI-IRQ
And the BIOS downloads are here:
https://www.shuttle.eu/_archive/older/de/bios … les.htm#sockel8
Doesn't look like the single and dual socket boards use different BIOSes.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 41 of 74, by chrismeyer6
Any luck getting the second cpu detected?
Reply 42 of 74, by wiretap
No luck on the 2nd CPU being detected. I had already tried the BIOS update. I'm just going to wait on some pictures of a dual socket board so I can see jumper settings. I don't want to damage anything by accidentally jumpering the wrong connections.
My Github
Circuit Board Repair Manuals
Reply 43 of 74, by amadeus777999
Looking forward to an update - very interesting!
Reply 44 of 74, by pete8475
Interesting project, I hope you eventually get it working with that second processor!
aka pete4237.5
Reply 45 of 74, by slivercr
moaaaar updatesssss
(just found this—pretty cool stuff!)
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 46 of 74, by wiretap
Stuck until I at least find some good photos of a real dual board. Project is shelved for now, but I check continuously for sale postings since that is probably the best hope I have to see a real board.
My Github
Reply 47 of 74, by PD2JK
Hope the 2nd CPU is getting detected, Nice Stuff!
has all kinds of stuff
Reply 48 of 74, by wiretap
<Spongebob: ONE YEAR LATER...>
Huge update..
I had a dream a few nights ago that I messed up the soldering on the Intel S82093AA chip. Well, I went back today and checked it -- sure enough, I had one leg that was ever so slightly bent and not making contact with the pad. I carefully bent it back down and reflowed it.. now it works!!!! No secret jumpers, no special BIOS, nadda. Just add the socket, capacitors inside the socket area, VRM header and VRM, and the S82093AA chip.
So if you want to get a dual Pentium Pro out of this board, you just need to follow what I did in this thread. Case closed.
Here it is on the test bench with 2x 200MHz PPro's, 128MB EDO RAM, and an ATI Mach 64 ISA (lol).
My Github
Reply 49 of 74, by bofh.fromhell
That's some amazing work, gz!
Reply 50 of 74, by Doornkaat
Awesome! Congratulations on your success! 😃
Reply 51 of 74, by Sphere478
Woohoo!!! Nice!!! Congratts!
They made a single processor version of my board also. But luckily I have the dual version hehe
Lot of delicate work. Good job!
Sphere's PCB projects.
Reply 52 of 74, by luckybob
clean solder job too!
Reply 53 of 74, by pete8475
Very cool!
aka pete4237.5
Reply 54 of 74, by Garrett W
This is beyond cool and it's so surreal that you had a dream about it that led you to the discovery of the issue. Well done!
Reply 57 of 74, by wiretap
Yea that picture was before I cleaned the board just after soldering. Everything cleaned up nicely.
Now to build this into a case.. I have a 3-digit MHz display in a beige case that should suit it well. Any recommendations on an OS? Windows NT4? Some early variant of linux with dual CPU support?
My Github
Reply 58 of 74, by chrismeyer6
SWEET! I'm glad you were able to get this solved. I can't wait to see the finished system now.
Reply 59 of 74, by Sphere478
wiretap wrote on 2021-03-04, 13:07:
funny you should ask I'm going through the same fun at the moment, try server 2003 standard r2 see if it works. it has gpt support and pressing f5 at startup on it or xp/2k/mce should bring up a menu with mps multiprocessor as a option
as for linux try debian jessie followed by older versions if that doesn't work jessie works on my k6 but not on my dual 233 mmx so wheezy might be the trick. use one of those xlcs xfce whatever desktop environments I for get their exact name but you'll know when you see the options. the other options will be slow.
btw, order 4 128mb sticks from ebay for that thing. there is a set for sale of some hp sticks that are registered and buffered right now
server 2003 didn't work for me it bluescreens after first reboot but windows media center edition and xp sp3 seem to work alright
for storage pickup a promise tx4 300 card I've had great luck with booting to them and great speed from them
if you get the chance, dump the bios and open it in awdbedit if you see a acpi table let me know and we can probably stick windows 7 on that thing I have a Iso file that will work with les than 512mb of ram but you won't need it if you pick up that ram
as for doing things I haven't been able to beat 7 I am constantly using it to rescue the other operating systems on my k6 build 🤣 I wish my dual pentium had acpi cause I'm pretty sure it would run very nicely on it
can't stress enough how impressed I've been with 7 if you have acpi try it.
also, look into pentium pro over drives on ebay you can bump that up to a 333mhz pII I think
check out my signature for the dual socket 7 build
