Reply 40 of 40, by bloodem
- Oldbie
mawendir wrote on 2022-06-08, 16:20:Thanks a lot, I got a 250W PSU already, gonna try it out first and see. Just two more questions. Is there a guide to install SATA SSD to W98 machine? And is it enough just put the sound card to PCI slot and will it work just fine, or do I need to plug a cable in to make the sound work?
Enter the BIOS setup menu, go to Storage configuration, and change the ATA/IDE configuration from "Enhanced" to "Compatible/Primary SATA+PATA". After doing so, the SATA SSD will behave like a good old fashioned PATA HDD.
Nothing else needed for sound. You only need to plug a cable if you want "legacy" analog CD Audio (probably not on this type of system - though it depends on what games you want to try out and how old they are).
Regarding the Audigy 2 ZS in particular, make sure that you switch to VXD drivers, instead of WDM (which is the default).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
