flupke11 wrote on 2022-05-30, 15:10:
Never knew the P5PE-VM had become expensive, I got at least 5 from a sale.
Yeah, all motherboards that offer Core 2 Duo support, AGP and full Win98 compatibility are generally expensive and harder to find nowadays (although, if you're lucky you can still find them for cheap on local listings).
subnet_zero wrote on 2022-05-30, 14:58:
What might be a cheap and compatible alternative for such a system?
It depends... If we're talking about a much more compatible (Win98 friendly) alternative to the GeForce 6600/6800 series (and similarly powerful), then there's only one option: one of the Radeon X8xx variants. I've tested all of my favorite games with these cards, and I've had no issues. And if you really want 100% compatibility, you can probably throw a Voodoo 2 in the mix (for Glide games + those few early Win95/98 games that might have issues with the Radeon X8xx).
Oh... right, you also said cheap. 😅 Uhm... the X8xx cards can sometimes be found for a cheaper price, but you'd need to be a bit more patient.
Of course, there are also cards like the Radeon X700 PRO/X600, which are still good and cheaper alternatives (the X700 PRO is generally 20% slower than the GeForce 6600GT, but much more compatible in Win98).
On the nVIDIA side, when it comes to Win98 compatibility & performance, there aren't any real alternatives to the ATI Radeon X8xx. As cyclone3d said, the fastest you can go while also maintaining very good compatibility is the GeForce FX 5950 Ultra (which is more than you need for Win98 anyway), however these cards are almost unobtainium nowadays.
A good alternative would be the GeForce FX 5900XT (also generally overkill for Win98), which with a bit of luck and patience can still be had for more affordable prices and it's capable of running any Win98 game at very high resolutions.
I'm not even going to mention the GeForce FX 5700 Ultra, because this one is also very rare and quite expensive.
So... now we get to the much cheaper (but also much slower) cards like the GeForce FX 5700/5700LE (in the case of the latter, you need to hunt down the 128 bit version, since there are a lot of 64bit variants on the market!). The GPU on the 5700LE is heavily factory underclocked (and so is the memory... depending on the model), so you can get exceptional results through massive overclocking (basically reaching GeForce 4 Ti 4200 speeds).
Which, yeah, brings me to the GeForce 4 Ti 4200 itself. Great card for Win98, and even though it's getting harder to find, you can still sometimes find it for $30 or so. Obviously, it won't come close to big boys like the FX5900/5950 Ultra, but it's generally able to sustain 60+ FPS @ 1600 x 1200 in most Win98 titles.
Bottom line, if you want the best of the best for Win98, then the Radeon X850XT PE is it. 😀
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
