Reply 40 of 45, by RETROKOMODO
Whaaaaaaa? I'll be doing this ASAP!
The Sandman wrote on 2022-09-24, 11:18:Guess it's the well known SSE instructions and more than 2-GHz problem with these Ati's. Try installing the CSA Patch http://vog […]
http://vogonsdrivers.com/getfile.php?fileid=1825&menustate=0
Must be installed in safe mode. Read the readmeWhat to expect from an NF7 and a Radeon 3850 AGP:
https://hwbot.org/submission/4774053
I decided to try my X800 in my Socket A system, and 3D 2001 restarts the system right after the Nature test. I remembered this thread, and I decided to install the CSA patch. But when I install the patch (in Safe Mode) I get the error "This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem." This is with a fresh install of XP and Catalyst 10.2 drivers. The card works fine in a Pentium 4 system, and this system works fine with an Nvidia 6800 GT. Any suggestions?
I found the answer on another old forum: I needed to install the Microsoft Visual C++ 2005 SP1 Redistributable Package (x86). Once I did so, the patch ran with no issues.
Good to know as I haven't got round to doing this myself yet.
Thank you for sharing this patch, solved for me too.
X1650Pro + XP-M
I´ve lost some hair trying so much settings haha
Pentium MMX 233@266| M537DMA | 48MB SDR | Trident 9685 4MB TVOut | Soundblaster 16
2x Pentium III 1000EB | CUV4X-D | 1,5GB PC133 | TNT2 Pro GA-660 | 80GB HDD | SB Live! 5.1
XP-M 2200+ | A7V600-X | 1GB DDR400 | Radeon X1650 Pro AGP | WD 80GB SATA
Repo Man11 wrote on 2022-10-28, 00:24:The Sandman wrote on 2022-09-24, 11:18:Guess it's the well known SSE instructions and more than 2-GHz problem with these Ati's. Try installing the CSA Patch http://vog […]
😀I decided to try my X800 in my Socket A system, and 3D 2001 restarts the system right after the Nature test. I remembered this thread, and I decided to install the CSA patch. But when I install the patch (in Safe Mode) I get the error "This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem." This is with a fresh install of XP and Catalyst 10.2 drivers. The card works fine in a Pentium 4 system, and this system works fine with an Nvidia 6800 GT. Any suggestions?
Yup this fixed it for me ... I just ran Legacy Update and made sure Windows XP was fully updated 😀
Windows XP Rig - Athlon XP 3000+ - EPoX-EP-8RGMI - 1GB Ram DDR - 60GB OCZ SSD - Audigy 2 ZS - XFX 6800XT AGP 256MB
Further update ... I am just going to call it a day running an AGP X1950 GT with my Athlon XP 3000+ on the whole they just don't play nice together 🙁 so I have gone back to using Geforce 6800XT in this build.
Toxy wrote on 2024-03-05, 21:51:Repo Man11 wrote on 2022-10-28, 00:24:The Sandman wrote on 2022-09-24, 11:18:Guess it's the well known SSE instructions and more than 2-GHz problem with these Ati's. Try installing the CSA Patch http://vog […]
