Reply 40 of 43, by The Serpent Rider
It doesn't matter in which order the drivers are installed. Usually. But apparently in Ydee case the AGP problem is fixed when VIA GART driver is installed last.
Reply 41 of 43, by shevalier
The Serpent Rider wrote on Yesterday, 16:23:
It's difficult to install the network card driver first if it's not listed in the OS device manager at all.
I wouldn't be writing about this with such confidence if I hadn't spent half a day replacing several network cards 20 years ago.
That's why I still remember these subtleties.
In Windows 98, 4-in-1 technology almost completely reconfigures the chipset, as the VIA support implementation in the BIOS\OS build-in drivers turned out to be less than ideal.
At least in the Award BIOS.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 42 of 43, by Ydee
I have to admit, I have the onboard LAN, AC97,LPT and COM disabled in my BIOS. So I don't know if the W98 would have any problem without installing 4in1 drivers if I had everything enabled, but I turn off anything I don't use.
I just wanted to write that when installing 4in1 drivers as the first software after installing the OS itself, the AGP texture acceleration was disabled and unavailable. When I installed the 4in1 package after forceware drivers were installed, the acceleration switched on and can be turned off - before the button was inactive.
Of course, I don't know if this will help solve the buggy problem every time, but I haven't had a chance to get any older versions of the BIOS (the oldest version is from 2006), changing the speed of the AGP (8x to 4x) hasn't helped, and other tips on the solution haven't worked either. The procedure described above solved the problem in my case.
Reply 43 of 43, by shevalier
Detonator most likely reads the state of the chipset registers; if it doesn't like something, it disables AGP memory.
At the time, Nvidia drivers were actively changing modes due to stability issues with VIA-based motherboards.
It would be interesting to compare Nvidia driver registry keys for different installation methods.
Perhaps we can identify key something like "AGP RAM disabled" or "Capability mode on."
