DOSBox ECE (for Windows & Linux)
Reply 400 of 1571, by KainXVIII
Dosbox 0.74 vanilla - overlay works, but its glitched when it try to disappear (alt+enter will help), like on your video. I think that same behavior was with old ScummVM, not it works alright too.
Dosbox 0.74 svn (comes with AR) - overlay works without disappear glitch (yay!)
Reply 401 of 1571, by Yesterplay80
So Steam either compiled a fixed version themselves or they're using an older version, that works better with overlays than the recent ones. Does the version of SDL differ maybe?
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 402 of 1571, by KainXVIII
SDL version in vanilla dosbox - 1.2.13
SDL version in Alien Rampage dosbox svn - 1.2.14 (but it does not have any copyrights on info page, maybe its indeed custom modified)
SDL version in ECE build (which does not show overlay at all) - 1.2.15
Reply 403 of 1571, by Yesterplay80
Could you, just for fun, try to run the game using DOSBox ECE, but with the SDL.dll supplied with the game (1.2.14)? I'm not at home atm, so I can't try that myself.
Reply 404 of 1571, by KainXVIII
I tried, still same result - overlay not showing up 😕
Reply 405 of 1571, by Qbix
Rank DOSBox Author
DOSBox Author
how about the build I linked you, with the SDL.dll of the game ?
Water flows down the stream
Reply 406 of 1571, by KainXVIII
With your build and SDL of the game - overlay works, but disappear glitch persist.
Reply 407 of 1571, by Yesterplay80
Strangely, the exact same thing happens here on my PC with ECE and vanilla, too. So it seems to work "normally".
Can anyone else confirm these problems only occur with ECE?
Reply 408 of 1571, by Crimson_Zero
I'd like to thank you for compiling DOSBox ECE. Your build actually allows Lands of Lore 2 to be playable in glide mode when using the teleporters. With other builds, I've had to switch out of Hardware acceleration mode to use them and then switch back again. It's fantastic to have a build available that is up-to-date with some great features!
*If you read the earlier post with the bug report, please ignore. It was user error*
Thanks again!
Reply 409 of 1571, by osmanvielma
Spaz wrote:
In Hoyle 3 you can bypass this problem by starting the game with: SCIDHUV -fw 0 0 200 320. Use lower case on -fw or you will get an error message.
Tested with a few other SCI games and they seem to work OK (Eco Quest and Castle of Dr. Brain)
Can somebody please tell me what those command line switches actually do?
And a list of command list available?
In castle of Dr. Brain there is this possibility of using scidhuv -f, but I don´t have a clue of what this could do.
I´m really curious about these switches. Any documentation regarding the use of these?
Thank you
Reply 410 of 1571, by brad86
Hi guys.
Is there any way of getting Reshade to work with ECE?
I use the recently ported CRT shaders on various emulators and would like to try my Lottes VGA preset on dosbox.
Unfortunately, no matter which api I choose on the Reshade install, nothing shows up when playing. Even when changing dosbox graphics output from pixel perfect to OpenGL.
Reply 411 of 1571, by Yesterplay80
ReShade only works with DIrect3D, so no.
Reply 412 of 1571, by brad86
Reshade works on D3D9,10,11, and openGL
Reply 413 of 1571, by Yesterplay80
Oh, the last time I used it I recall it supporting D3D only.
It works here, here I applied a CRT and a Nightvision effect to DOSBox ECE running ROTT:
Reply 414 of 1571, by Dagar
DOSBox ECE and Reshade works good here.
DOSBox ECE and Reshade with the CRT filter set up properly looks really, really good.
I noticed that you can't go over Brightness 0.600, and Gamma and Monitor Gamma over 2.000 or else the Reshade GUI overlay will not disappear properly and color glitch.
That issue is a problem of Reshade, not DOSBox ECE but I thought I'd mention it.
Reply 415 of 1571, by brad86
All good now. Not sure if it was my older version of Reshade or how my preset was done.
Now using the latest version and everything is working.
Thanks guys.
Reply 416 of 1571, by lukeman3000
Hey Yesterplay -
With r4134 I seem to be getting a strange sound glitch as seen here. I tested with vanilla DOSBox (v 0.74) and did not experience this (nor did I with previous versions of ECE) Any ideas?
Also, here is my DOSBox conf file if needed.
Reply 417 of 1571, by Qbix
Rank DOSBox Author
DOSBox Author
Just wait a little bit.
The problem is known and a solution exists, waiting to get it pushed to the right locations
Reply 418 of 1571, by Delfino Furioso
I've decided to give ReShade a try...
Do you mind sharing your config params for the CRT filter?
Thanks
Reply 419 of 1571, by Danfun64
Since a new version of ECE hasn't been released yet, and since I don't know if the fix for this issue has been committed to the regular dosbox repository, what was the last version of ECE that didn't have this problem?
