PCMCIA Sound Cards
Reply 420 of 754, by Bondi
bjwil1991 wrote on 2021-11-12, 04:12:
Won a KXL-DN745A on eBay (well, made an offer lower than the asking price) with basically all of the entails/trimmings:
I know it's Adlib support, which my NEC laptop really needs as it only has WSS, which is only SB and no FM.
I think this is a Japanese import model (the manual and diskette have the Japanese language on it).
That's a nice card. You can also try the Doom and Wold3D mods I mentioned above. They should work with both Adlib and digital sound.
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
68pins.com custom PCMCIA drivers
Reply 421 of 754, by bjwil1991
Got the goodies yesterday afternoon.
Gotta translate the manual and the back of the drive to English.
The attachment IMG_20211116_030842332~2.jpg is no longer available
Reply 422 of 754, by Bondi
bjwil1991 wrote on 2021-11-16, 08:18:
The english manual is available online https://static.fixya.com/Manuals/P/Panasonic/ … 250D38B689B.pdf
Reply 423 of 754, by MAZter
digger wrote on 2020-10-21, 20:48:
Indeed, I don't know of any Pentium laptops that did not come with on-board Sound Blaster compatible sound support. (If anyone reading this knows of any, please share!)
Easy. Toshiba Satellite 110ct come with no sound card and with Pentium processor. And it works fine with I/O Magic Tempo.
Doom is what you want (c) MAZter
Reply 424 of 754, by Bondi
MAZter wrote on 2021-11-19, 16:56:
Anyways the market for this card was very slim as pentium laptops without sound card were rare.
Do you own a I/O Magic Tempo card? Can you make some pictures?
Reply 425 of 754, by drastikterror
HI!
I would like to ask you if there is any possibility to use Roland Scp-55 PCMCIA card under Linux.
"-Roland SCP-55
SoundCanvas and MPU-401 GM device in DOS + digital audio in Win3.x/Win9x
Drivers for DOS/Win3.x/Win9x: http://www.rolandus.com/support/eula/SCP55.EXE
For Linux and for the HP100/200LX: http://zo-kun.to/~risyu/scp55/
Manual: http://media.rolandus.com/manuals/SCP-55_OM.pdf
Unfortunately the link for Linux driver doesn't work!
Reply 426 of 754, by lolo799
drastikterror wrote on 2021-11-20, 09:21:
HI! I would like to ask you if there is any possibility to use Roland Scp-55 PCMCIA card under Linux. "-Roland SCP-55 SoundCanva […]
HI!
"-Roland SCP-55
Web links unfortunately die sometimes.
Drivers and translated readmes attached below:
The attachment scp55-pkg-1.01.tar.gz is no longer available
The attachment scp55.README.eng.txt is no longer available
The attachment scp55.INSTALL.eng.txt is no longer available
The attachment scp55_hp.lzh.zip is no longer available
The attachment scp55-hp200lx.txt is no longer available
Reply 427 of 754, by drastikterror
lolo799 wrote on 2021-11-20, 12:34:
HI!
"-Roland SCP-55
Drivers and translated readmes attached below:scp55-pkg-1.01.tar.gzscp55.README.eng.txtscp55.INSTALL.eng.txtscp55_hp.lzh.zipscp55-hp200lx.txt
Hi! Thank you so much!
Can't wait to try them on my 32 bit laptop. The Roland SCP-55 deserves to be still active! She has a great sound!
Reply 428 of 754, by drastikterror
Is there anybody which already tried Roland SCP-55 under Linux? If so, please, some advice on how to use the drivers?
Sorry, but I'm really a noob!
Reply 429 of 754, by lolo799
drastikterror wrote on 2021-11-20, 15:10:
Did you read Install.eng.txt?
What kernel version are you using and on what hardware?
The linux driver here is for 2.0.x kernel series, working fine on 2.0.36, which is RedHat 5.2, so, really old.
You'll need to follow the instructions to patch a file, have the pcmcia services installed, and compile a new kernel with the options set as written in the readme...
Reply 430 of 754, by drastikterror
lolo799 wrote on 2021-11-20, 15:29:
Did you read Install.eng.txt? What kernel version are you using and on what hardware? The linux driver here is for 2.0.x kernel […]
I would install a NEW AV Linux MX Edition, which has a 5.10.52 kernel, so I'm not sure if I can use the card with this distribution.
Reply 431 of 754, by lolo799
drastikterror wrote on 2021-11-20, 15:43:
What laptop will you use?
I guess you can start by installing the distro in question along with the kernel and modules sources, the dev utils needed, and start comparing between the old pcmcia-cs that's being patched and the pcmcia support included in the 5.10.52 kernel...
Reply 432 of 754, by drastikterror
lolo799 wrote on 2021-11-20, 18:10:
It's an old Compaq Presario X1000, 2 GB Ram, Intel Centrino 1.4 GHz.
Reply 433 of 754, by bjwil1991
I'm currently testing the KXL-DN745A on my Austin TFT 486 laptop (disabled the internal Sound card for testing purposes) and it gives me this:
Sound/CD-ROM Interface Card Driver Ver. 1.01 (960129)
for IBM Card Services 1.07 / 2.00
for SystemSoft Card Services 2.012.10
for Phoenix Card Services 2.00 / 2.01 / 2.10
All Rights Reserved, (C) 1995, 1996 KYUSHU MATSUSHITA ELECTRIC CO., LTD. (C)Copyright 1993, 1994, 1995 RATOC System Inc. Osaka Japan
IObase=0x 280, IRQ = 5, Socket = 0
Unable to get I/O Window.
Driver Unloaded.
CD-ROM Device Driver KMECD Ver. 1.71 (951102) All Rights Reserved, (C) 1994, 1995 KYUSHU MATSUSHITA ELECTRIC CO., LTD. (C) Copyright 1994, 1995 RATOC System Inc. Osaka Japan
ASPI Manager Mot Installed.
Driver Unloaded.
Device driver not found: 'PCMCIACD'.
No valid CDROM device drivers selected
I even tried the one for the CardTalk driver and that doesn't work either.
I'm using the English drivers since the Japanese one I cannot read at all (random letters and numbers).
Am I missing something here? In Windows for Workgroups 3.11, it doesn't work either.
Reply 435 of 754, by lolo799
bjwil1991 wrote on 2021-11-21, 10:57:
I'm currently testing the KXL-DN745A on my Austin TFT 486 laptop (disabled the internal Sound card for testing purposes) and it […]
Driver Unloaded.
Driver Unloaded.
Can you post your config.sys and autoexec.bat?
Reply 436 of 754, by bjwil1991
Bondi wrote on 2021-11-21, 11:16:
Which driver do you use? IIRC aspis365.sys worked fine and did not require CS and SS. It is also possible to set port address and irq using /PORT= /INT= switches
The ones I attempted to use are aspis365, aspismgr, and aspisdbk. All of which fail to initiate and my laptop uses the Databook CardTalk driver set. I changed the IRQs and port addresses to no avail, even leaving the thing blank does nothing.
Unfortunately, my NEC laptop died all of a sudden and cannot be used to test the drive out.
Reply 437 of 754, by lolo799
bjwil1991 wrote on 2021-11-21, 11:24:
Do you have SystemSoft Socket and Card Services loaded in order to use aspimgr.sys?
For aspisdbk, you need to exclude a memory range in the emm386 line in config.sys, it's detailed in the readme, and try using another IO address.
Reply 439 of 754, by bjwil1991
CONFIG.SYS:
DEVICE=C:\DOS\HIMEN.SYS
DEVICE=C:\DOS\MM386.EXE NOEMS X-CE00-CFFF
BUFFERS=40,0
FILES=40
DOS=UMB
LASTDRIVE=Z
FCBS=4,0
DEVICEHIGH L:1.12048 =C:\DOS\SETVER.EXE
DEVICE=C:\DOS\ANSI.SYS
DOS=HIGH
DEVICE=C:\PCMCIA\CARDSOCK.SYS
DEVICE=C:\PCMCIA\CTALKCS.EXE
DEVICEHIGH L:1,57856 =C:\PCMCIA\CARDTALK.SYS /A IOW=300-31F /MEM=CE00-CFFF
DEVICE=C:\MCDRM\ASPISDBK.SYS /PORT=280 /INT=5 /ADLIB /MEM=CE00
DEVICE=C:\MCDRM\KMECD.SYS /D:PCMCIACD
rem devICEHIGH=C:\PCMCIA\CTALKID.EXE
DEVICEHIGH L:1,4560 =C:\WINDOWS\IFSHLP.SYS
STACKS=32,256
DEVICE=C:\DOS\DRVSPACE.SYS /MOVE
And it gives me the error:
Databook CardTalk Not Loaded.
Driver Unloaded.
Reinstalling the drivers is out of the question since there aren't any installation programs on the hard drive (that came with the system) and on top of that, there aren't any drivers online for the PCMCIA slot.
My EXP CD-ROM drive works with it, however. Maybe I need to use the Japanese diskette to get it to work, eh?
