Some days ago I obtained an Intel SR440BX. 😀 A µATX Slot-1 Mainboard with Riva TNT graphics and an Audio PCI 64V. It has one ISA slot for the usual Retro soundcard goodness. All this makes for a very compact setup.
Coppermine CPUs
In regards to running coppermine Pentium III Processors on this board. With any BIOS newer then Version P06 you will get this message at boot:
"Warning : This motherboard is not compatible with this processor's voltage requirements. The system has been halted." etc.
P10 is the latest BIOS.
BIOS Versions P06 and earlier will run with a coppermine CPU without complaining. Usually it is written that this board cannot give a Core Voltage below 2 Volt, as required by coppermines. But this is unlikely:
P-III 450 /512/100/2.0 V S1 SL35D: I measure 2,06V
P-III 600E/256/100/1.65V S1 SL3H6: I measure 1,70V
P-III QH31ES @3.5x66=233MHz: I measure 1,68/1,69V
I measured at the underside of the board next to where one leg of the large coil is connected.
What is more likely is that the voltage regulators have trouble with high currents at the lower voltages. That and marketing decisions.
BIOS
With most BIOS versions I can just go to Setup with the F2 key, and I can leave that configuration mode jumper alone.
There is not much of interest in the BIOS, just the basics.
Newspeed
So on this board I could test the mysterious intel Newspeed.exe tool.
I tested it with about 5 different P-IIs and P-IIIs. What is common is that every 66MHz FSB Processor was set at 233MHz by default, every 100MHz FSB Processor was set at 350MHz by default. A 100MHz processor that I previously rewired to a 66MHz FSB was also at 233MHz.
So they were all reporting a value that translates to multiplier 3.5x. But this multiplier value was only actually used with the two (partially) unlocked CPU's I have. On the other CPU's this setting is totally ignored.
The (partially) unlocked CPUs could be given values higher then 3.5x, and they would run as such after reboot. Unfortunately the program would not accept any value below 3.5x (233MHz).
FSB speed
The FSB speed is determined with a CPU autodetect, through pin B21. The PLL IC does not even support anything else then 66 and 100MHz. CPU's with a 133MHz default FSB speed will not run on this board. I tried it, but the system does not boot. The SoftFSB software does not support this board.
