Reply 520 of 659, by candle_86
Standard Def Steve wrote:
candle_86 wrote:
Athlon 64 X2 6000 @ 14x230 3220mhz ASUS M2N-SLI - 8gb 920 DDR2 6-6-6-18 - 7900GTX 92.91 - XP Pro SP3 - SB Audigy 190.5 […]
190.5
So it seems I'm not maxing out my 7900GTX SLI at 10x7 then again i tested it and at 12x10 i get identical FPS so I guess i knew 🤣
Thanks for testing that! 😀
You've gotta be close to maxing out a single card, since you gain 11 fps from enabling SLI. On my Opteron, adding a second 8800GTS didn't improve performance at all; in fact I lost 1.4 fps.
Well I can test that I think. I have a Celeron Haswell with DDR3 1333, it should be able to push the 7900GTX has fast as possible I think.
Reply 521 of 659, by agent_x007
Soo...
I tested few things 😀
7800 GTX 512 :
218,6FPS : LINK
i7 3820 @ 5,03GHz - ASUS Sabertooth X79 - 8GB 2012MHz DDR3 8-9-8-24 CR1T - 7800 GTX 512 - 307.83 - XP Pro SP3 - ASUS Essence ST Deluxe 7.1
7900 GTX :
237,1FPS : LINK
i7 3820 @ 5,03GHz - ASUS Sabertooth X79 - 8GB 2012MHz DDR3 8-9-8-24 CR1T - 7900 GTX - 307.83 - XP Pro SP3 - ASUS Essence ST Deluxe
7950 GX2 OC :
359.1FPS : LINK
i7 3820 @ 5,03GHz - ASUS Sabertooth X79 - 8GB 2012MHz DDR3 8-9-8-24 CR1T - 7950 GX2 (600/1404) - 307.83 - XP Pro SP3 - ASUS Essence ST Deluxe 7.1
780 Ti OC :
611,8FPS : LINK Max. turbo at the game... 1020MHz 😀
i7 3820 @ 5,03GHz - ASUS Sabertooth X79 - 8GB 2012MHz DDR3 8-9-8-24 CR1T - GTX 780 Ti OC - 365.19 - XP Pro SP3 - ASUS Essence ST Deluxe 7.1
Reply 522 of 659, by candle_86
It's as I expected my a64 can't drive the sli @ 10x7 but it will at 1600x1200 🤣
Reply 523 of 659, by Standard Def Steve
A Pentium D performing similarly to a 3GHz Core 2 Duo is simply unacceptable. Even when the Pentium D is clocked at a mind bending 5GHz. 🤣
I rebenched the E6600, this time on a P45 based motherboard. It's simply incredible how much of a difference the chipset (and faster memory) makes. According to memtest86, the P45 w/ DDR3 provides almost twice the memory bandwidth of nForce 650i w/ DDR2-667.
261.7 fps, now that's more like it!
Core 2 Duo E6600 @ 3GHz/1333FSB, GTX 560 (353.06), 8GB DDR3-1333 CL7, Asus P5Q3 (P45), onboard audio, Win7 x64
1024x768 Ultra:
The attachment e6600-3ghz-P45-Doom-W7.PNG is no longer available
"A little sign-in here, a touch of WiFi there..."
Reply 524 of 659, by Skyscraper
Nice scores, the list should be up to date.
I addad two of agent_x007s scores with the i7 3820. The TX 780ti score, the third best score of all and the 7950 GX2 OC which is a really good score with a DX9 video card.
Standard def Steves score with the E6600 also earned an X.
Reply 525 of 659, by Tommaso72
Just wanted to add my score. I used the original game disk and I have Windows XP pro SP2.
System Specs:
P4 3.06 HT Northwood
GeForce FX 5800 Ultra 128 meg.
768 Meg DDR333 dual channel
ASUS P4P800 LE with 533 FSB
Sound Blaster Live 5.1 value
Results:
800 x 600 : High Quality: 55 fps
1024 X 768: High Quality: 54.5 FPS
1024 x 768: Ultra Quality: 50.7 FPS
My temperature was checked immediately after the third test and the GPU was only 50 degrees celsius. I have the stock cooler and I have read these GPUs have very high running temperatures. It doesn't seem the case here. Just thought I would add that.
Tommaso72
Reply 526 of 659, by Tommaso72
Alphawings system is very similar to mine posted above, but mine is p4 and his is AMD. Just thought the differences would be interesting, and why such a difference@
AlphaWing wrote:
Doom 3 - Amd Xp 3000+ Nf2 1GB DDR 400 DC, Geforce FX 5800 128mb SBLIVE! sound enabled timedemo demo1 1 […]
Default Medium Quality Settings.
640x480 = 54.2fps
800x600 = 52.1fps
1024x768= 43.0fps
1152x864= 37.3
1280x1024= 29.9fps
Ultra Quality
640x480=51.3
800x600=47.9
1024x768=38.7
1152x864=33.2
1280x1024=26.5
This is what I got with retail copy\last patch in a different thread with this particular machine.
I'll test it later on my socket 939 amd and socket 775 P4. Geforce 550 ti, Geforce 6600GT
Reply 527 of 659, by candle_86
640x480 = 54.2fps
800x600 = 52.1fps
1024x768= 43.0fps
1152x864= 37.3
1280x1024= 29.9fps
Ultra Quality
640x480=51.3
800x600=47.9
1024x768=38.7
1152x864=33.2
1280x1024=26.5
1.0 vs 1.3
My system gained 40FPS by using 1.0 vs 1.3 🤣
Reply 528 of 659, by Tommaso72
Would mine be version 1.0 if it was from an original disk and how is it possible to find the version number@
Tommaso72
Reply 529 of 659, by agent_x007
Version is on right side of console (place where U put "timedemo demo1 1" text) 😀
With original Disc's U should have v1.0.132 or similar.
Reply 530 of 659, by tincup
There are also text files in the 'docs' folder of your root install. Later versions have updated readmes.
Reply 531 of 659, by Standard Def Steve
Here's your first Skylake result. This is from a friend's new computer, an HP Envy Phoenix with a 980Ti and DDR4 memory. Honestly, the performance is a little underwhelming. It's much slower than my overclocked Ivy Bridge-E 4930K, which scored 651.7fps under XP and 621.1 fps under Win7.
i7-6700 (3.4 with 4.0GHz Turbo), GTX 980Ti (368.22), 16GB DDR4-2133, HP Z170 motherboard, onboard audio, Win10
452.7fps at 1024x768 Ultra.
Reply 532 of 659, by Skyscraper
That is almost exactly the same score as I got with my overclocked E8600 @4.8 + GTX 580 and that was with only 900 MHz on the GPU! 😀
I added the i7-6700 score to the list.
Reply 533 of 659, by agent_x007
First Intel Double Core still alive and kicking 😀
Pentium Extreme Edition 840 + 7800 GTX 512MB :
153,0FPS : LINK
Pentium XE 840 @ 4,27GHz - ASUS P5K64 WS - 8GB 1069MHz DDR3 5-5-4-12 CR1T - 7800 GTX 512MB - 307.83 - XP Pro SP3 - SB X-Fi Elite Pro
Pentium Extreme Edition 840 + GTX 780 TI :
165,1FPS : LINK
Pentium XE 840 @ 4,27GHz - ASUS P5K64 WS - 8GB 1069MHz DDR3 5-5-4-12 CR1T - GTX 780 Ti - 365.19 - XP Pro SP3 - SB X-Fi Elite Pro
Reply 534 of 659, by agent_x007
SLI is so much fun 😀
206,7FPS : LINK
Core 2 Extreme X6800 @ 3,2GHz - ASRock 4CoreDual-SATA2 R2 - 4GB 533MHz DDR2 4-4-3-9 CR2T - 7900 GX2 - 307.83 - XP Pro SP3 - SB X-Fi Elite Pro
Reply 535 of 659, by Imperious
Single Core Power! Will be interesting what the 7800gs can do a bit later on.
116.8 FPS, Imperious, Pentium M@2712MHz, Nvidia 6800GT@425-2300 93.71, 2048MB DDR452@2,3,2,5 Asus P4P800dlx, Onboard Audio, XP-SP3
Reply 536 of 659, by Mamba
I really would like to test my S940 Platform... But It seems that the Demo doesn't run on Seven 64bit...
Reply 537 of 659, by Imperious
Managed to squeeze a bit more from the Pentium M, also 7800gs, system far from stable though.
130.9 FPS, Imperious, Pentium M@2735MHz, Nvidia 7800GS@526-1591 93.71, 2048MB DDR456@2,3,2,5 Asus P4P800dlx, Onboard Audio, XP-SP3
Reply 538 of 659, by Skyscraper
I have updated the list 😀
Reply 539 of 659, by Tommaso
Just a quick question, I did the time demo and had a score of 52 frames per second and it was with 756 megs of DDR 400. I then didn't change anything ther than adding different ram to get 1 gig, but I changed all the sticks, and it happened to be DDR 333. Then I ran the test again and lost 10 frames per second. Does ram speed effect frames per second this much, even when it is 256 megs more? Thanks in advance!
