Reply 5300 of 59486, by F2bnp
- l33t
Hey, I recognise that small FM radio! Used to have one as a kid too 😀.
Lol I can't tell you how many of those I've seen in junk stores around here.
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Nice to see a big brother of my Satellite 200CDT getting showcased. The question is though; can it last for nearly an hour on a full charge like mine still can, with the original battery? 😜
I bought these a few days ago, but they just came today. Close enough.
From top left to bottom: AudioPCI, Matrox Mystique 220, Intel SE440BX-2 (I think so anyways. Seller had "Seattle2" in the title and it sure looks close to an SE440BX-2).
Musician & music gear/game reviewer.
MIDI hardware: JD-990, SC-55, SC-880, SD-90, VL70-m, Motif ES, Trinity, TS-10, Proteus 2000, XK-6, E6400U
Bought a couple of retro gear past days:
- a generic Voodoo 1 card (condition unknown, not tested yet)
- an S3 based ELSA Winner 2000Pro/X-PCI-4
- a Roland MT-32 (old one) with some scratches & dents, but otherwise fully working. It will make a nice complement to my Roland CM-300 😀
- K5 CPU to my humble collection, supposed to be OK. , I am waiting for the postman
I am sorry for the pictures quality, just made quick shots with my mobile.
98 runs pretty ok if you have 64 MB of RAM especially if you have a 486/100 but even a 66 should be workable.
Its W2K that gets painful
wrote:98 runs pretty ok if you have 64 MB of RAM especially if you have a 486/100 but even a 66 should be workable.
Ever tried XP with only 64 now that makes W2K look a lot better. 😵
Got a box full of stuff from the junkyard again... found many unusual ISA and VLB cards this time. Also some 386 boards with Cyrix 387, are these any good?
I love that every MT-32 has that ring of fingertip-wear around the volume knob.
That is beautiful. I like the angled front especially. Is the logo correct in that it has a 486DX2?
wrote:wrote:98 runs pretty ok if you have 64 MB of RAM especially if you have a 486/100 but even a 66 should be workable.
XP runs badly enough with 256MB, in my experience!
wrote:wrote:wrote:98 runs pretty ok if you have 64 MB of RAM especially if you have a 486/100 but even a 66 should be workable.
Agreed. I can't imagine it on 64MB; I've seen W2k on 64MB and it was bad enough. 😵 But agreed that for 98 it shouldn't be too much of a problem - if memory serves the last 98 install I did it was "idle" on the desktop with only ~30MB of memory in-use (the entire install was only like 200MB), whereas W2k and XP tend to want to hover around 100MB.
I just finished identifying most of the stuff I got today. Here's a list:
- Video:VLB - Tseng ET4000/W32P (6x)VLB - Diamond Stealth 64AGP - ATi Rage 128 Pro Ultra 32MBAGP - Number Nine SR9 DVI (2x)AGP - nVidia Vanta-16 (2x)AGP - 3dfx Voodoo3 3000AGP - 3dfx Voodoo Banshee (Magic TwinPower)PCI - 3dfx Voodoo3 2000PCI - ATi Mach64 GT (+ daughterboard)ISA-8 - ATi Small Wonder Graphics Solution v2ISA-8 - V-Tech Laser CGA/HerculesISA-8 - TECMAR (CGA/EGA/Herc???)ISA-16 - DFI VG-5000 (Tseng ET4000AX) (5x)ISA-16 - Tseng ET4000AXISA-16 - iCL CL-GD5428 (made in Finland!)ISA-16 - OAK OTI067 VGA (CGA/EGA/Herc too?)ISA-16 - OAK OTI077 VGA (2x)ISA-16 - OAK OTI087 VGAISA-16 - OCTEK PVGA1C (WDC WD90C11A)ISA-16 - Trident TVGA8900C (4x)ISA-16 - Trident TVGA8900DISA-16 - Trident TVGA9000BISA-16 - Trident TVGA9000C (3x)ISA-16 - Ahead AVGA V5000- Audio:ISA-16 - Crystal CS4236ISA-16 - ASC Trouper 4x4 ??? (broken) (SB16 compatible?)ISA-16 - Highscreen Sound-Boostar [sic] 16/32 (AD1816AJS)ISA-16 - Yamaha YMF719ISA-16 - PC Chips (?) CMI8330AISA-16 - Aztech AZT2320PCI - Creative SB Audigy SB0570- I/O:VLB - UMC I/O controllerVLB - Winbond I/O controllerISA-16 - CGS Prime3B I/O controllerISA-16 - unknown I/O controllerISA-16 - Siemens Nixdorf Profibus adapter ?ISA-16 - V-Tech Laser LPT/COM card ?ISA-16 - Acer I/O controller (2x)ISA-8 - Some more LPT/COM cards (I think)PCI - NetMos NM8935CV dual COM card?- Misc:Slot 1 - Asus S370-DL slocket (with retainer clips and voltage select) (6x)ISA-16 - Siemens Nixdorf SAS-DUE adapter III ???ISA-16 - Artisoft LANTastic 2MbpsISA-16 - 3Com Etherlink III (2x)ISA-8 - Logitech Scanman PlusISA-8 - Chinon 43001JC-EP10A card ??? (only external port)ISA-8 - WDC WD1002A-WX1 MFM hard drive controllerISA-8 - Hewlett-Packard SCSI controllerPCI - Lenten RebornXP (14x)PCI - Winbond W89C940F ethernet cardPCI - Intel S87557 ethernet card
- Mainboards:Slot 1 - Compaq unknown, i810 (what!), 2x ISA-16, 5x PCISlot 1 - Gigabyte GA-686KX, i440FX, 3x ISA-16, 5x PCISlot 1 - MSI MS-6119, i440BX, 3x ISA-16, 1x AGP, 4x PCISocket 7 - Abit AB-AX5, i430FX, 4x ISA-16, 4x PCISocket 3 - Gemlight/Vextrec GMB-486SG, SiS 85C471, 3x ISA-16, 3x VLB,Socket 3 - Bioteq MB-1433/50UIV-A, UMC UM4898F, 4x ISA-16, 3x VLB,Socket 3 - unknown, ALi M1489, 4x ISA-16, 3x PCI386 - Uniron unknown, Am386SX-25 + Cyrix 387, 6x ISA-16, 1x ISA-8386 - unknown, Am386SX-25, 6x ISA-16, 2x ISA-8XT - unknown, no CPU, 8x ISA-8XT - Philips NMS9100 (broken)
I'm especially happy about finding a PCI Voodoo3 and all those Hercules cards 😀
And that Logitech PS/2 card, didn't even know these existed!
wrote:And that Logitech PS/2 card, didn't even know these existed!
It's probably a MousePort card, not PS/2. (Like this? Bought a Logitech 270120 8bit ISA Mouse port card, any info? )
If it IS a PS/2 card, then we really need to reverse-engineer it pronto.
wrote:wrote:And that Logitech PS/2 card, didn't even know these existed!
On closer inspection, you're right, it slightly different from a normal PS/2 port.
Looking up the number on the PCB however, reveals that this is actually a Logitech Scanman Plus card... An interface card to connect a handheld scanner. Oh well. 🙁
Many disappoint.
Time to upgrade Guile (Dual Slot 1 P3) to silly proportions.
Two 1.4GHz Tualatin PIII's with 512KB Cache. Probably will run them at 1050MHz because I don't like pushing my BX board to 133MHz for long periods of time. These slotkets have their own VRMs onboard to get around the voltage problem, I am prepared for microcode-related warnings.
For those of you who have never encountered the machine and wonder about it's current configuration I did [url=https://www.youtube.com/watch?v=X1X9HOQ6aKA[/url]a YouTube video on it a long time ago, early into using the formatted... err... format for my videos so it's not perfect. Another will follow in future if the upgrade is successful, planning on jamming a Radeon 4000 in there and seeing what happens if I run Crysis. Tempted to track down the RAIDPort thingy but I probably don't need it.
Got this Big Blue today... I´m not big fan of ibm but it´s kind of cool anyway 😀
IBM 300 GL Model 6282-730. P166 MMX, 64 mb EDO, somekind of hd and cd, haven´t check those out yet. Don´t know if it runs neither.
There's a little moisture inside, think i'm going to let it dry for few days 😀 took the heatsink off and it's cool ceramic MMX...Love those...
